Thread: How-to change lower control arms
Results 1 to 20 of 76
  1. #1 Re: How-to change lower control arms
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    I was able to cut thru the bolt. I only dulled two blades. The size of the bolt is M14-2.00 90mm. I used a metric 10.9 grade bolt which is the equivalent of a grade 8. I also decided to upgrade the sway bar while I was at it. There's a huge difference in the tightness of the steering. Glad I did it.
  2. #2 Re: How-to change lower control arms
    SE Level Member fmayo's Avatar
    massachusetts
    Quote Originally Posted by tdm571 View Post
    I'm getting ready to do this job on my '06 GP base. Does anyone know all the bolt sizes for the LCA? I'd like to replace them all when I swap them out but would like to have them on hand. The car is my daily drive so I'm not running to the store once I start tearing things apart.
  3. #3 Re: How-to change lower control arms
    massachusetts
    I got lucky with the PB Blaster I guess, the torx bolts came out without too much trouble. I did pick up new bolts before hand though but had trouble finding metric bolts in my area. Ended up using a 9/16" x 4" #8 bolts to replace the torx bolt. Make sure you get some good washers too so the hex head doesn't cut into the aluminum sub-frame.
  1. Replacing lower control arms
    By Linebacker in forum General Tech Discussion
    Last Post: 08-01-2021, 05:53 PM
  2. 2004 GT2 Lower Control Arms
    By apok in forum Brakes/Suspension/Chassis
    Last Post: 04-24-2012, 10:21 PM
  3. 97-03 vs 04+ lower control arms
    By Wicked13 in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2010, 10:17 PM
  4. Lower Control Arms
    By SyntheticShield in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2009, 12:55 PM
