Quote Originally Posted by joe0813 View Post
be careful on the bolt with the torx bit.... some strip out... and some like on mine freeze to the bushing and wont come out. when this happens what i did was cut the bolt with my snap on straight cut off wheel and then go to a hardware store and got a grade 8 bolt and nut. MAKE SURE ITS A HARDENED STEEL BOLT!!... or if you dont want to cut the bolt... carefully cut the sleeve with a cut off wheel vertical and stick a pry bar in between it so it wont spin on you. But your better off just cutting it on and getting rid of the dumb torx bolt anyway
I just attempted to change my LCA's and sure enough mine are seized in the sleeves. I'm going to cut them out and get some new bolts without the torx head. Other than grade 8, what are the specs for the nut and bolt? Also, what type of blade do I need for my reciprocating saw to cut it out?
