I'm not seeing a way to insert my grease gun hose into my lca lower ball joint (behind the rotor). However, I do see one on my outer tie rod. I just replaced my whole rod and when I tighten the lug nut in between them the whole outer tie rod twisted and is on my mount a bit slanted. Can this be ok if I am sending the car to get it alligned anyways?
