Thread: How to tell if you have the GOOD Lower Intake Manifold gaskets.
Results 21 to 40 of 42
  1. #21 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    good stuff. green is always the way to go.
    u do have the car apart right? like you didnt flush the coolant and add more to drive while you wait on the gaskets?
  2. #22 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Jan 2012
    Philadelphia
    i was doing like 80 down the interstate and layed into it then the coolant elbow blew out on me and all my coolant went every where so i flushed out the little dex-cool i had in there and replaced it with the green. im doing the LIM gasket once i have all the parts for my gen 5 swap and once i finish polishing it. the car is back together its been i fixed it all last night im not gonna leave it apart its my DD not a show car lol
  3. #23 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Minnesota
    GM seem better than the Felpros to me. I have the GM ones on my car and wouldn't use any other.
  4. #24 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Quote Originally Posted by bps02gtp View Post
    ull get a few years out of em. maybe 50 to 80k miles. if u left the dex cool in there it seems to tear the gaskets up a little bit faster. the good ol green stuff doesnt hurt it as bad.
    But then green and dex have a party.
    And green by itself isn't so great when it comes to pitting of aluminum.
    Use long life coolant and just replace it at proper intervals like you're supposed to.
  5. #25 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Jan 2012
    Philadelphia
    so you think Dex-cool is a better choice?
  6. #26 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    I do.
    At the very least something like prestone long life.
  7. #27 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Jan 2012
    Philadelphia
    I do.
    my car has had dex in it ever since i had it i just swapped to the green after i had my issue. when i replace the LIM i might swap back. i guess GM recommends it for a reason. ill probably do some more research on it
  8. #28 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Nov 2010
    Illinois
    well eddie then i guess you didnt have much choice. just sucks cuz ur gonna lose quite a bit of coolant doing the gasket replace.
    doesnt seem like theres much of difference with felpro and gm but i suppose thats personal preference. as long as you have the metal kind which is the 2nd design, you're in a better position.
    i dont like dex cool. sh!t stinks real bad if its old. which everything does but dex seems worse. IMO it tears through gaskets much quicker. if you do a proper flush you wont mix Dex and green because that is bad. so if its just green you're good. Dex seems more designed for enviornment friendly purposes. you have a good mixture of green and water then you cant go wrong. but thats just my opinion.
  9. #29 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Why state your opinion when you could go out and try and find facts?
  10. #30 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Jan 2012
    Philadelphia
    yea im just running what i have for now right now my coolant is 50% water im not worried about it ill see how the green holds up compared to the dex. just to see if i see a difference
  11. #31 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Minnesota
    I thought the green stuff was extended life already?
  12. #32 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Jan 2012
    Philadelphia
    i have no idea lol
    im just trying new things
  13. #33 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Quote Originally Posted by Pure2sin View Post
    You can still get old school ethylene glycol. Rated for 2 years and 120 000 km or 80 000 miles.
  14. #34 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Nov 2010
    Illinois
    I cant. i state that its my opinion because these are my experiences. i give my insight, you give yours, people read/do research and make a decision. i wont intentionally steer someone wrong by saying you absolutely cant use Dex but ill say IMO green is better. if you seem to KNOW Dex is better then y dont you educate us with your facts?
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    When people say they "flushed" out their coolant system to put green stuff in I always hope they did it correctly....
    The system should be drained and replaced with distilled water and a flushing agent.....then the heater should be turned on, run the car like that, repeat flush. Then flush with distilled water at least 2 more times. Also a good idea to change any rubber hoses
    This post brought to you by.....
    For all your 3800 needs:
  16. #36 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Jan 2012
    Philadelphia
    Quote Originally Posted by copgtp View Post
    what can happen if not flushed correctly?
  17. #37 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Nov 2010
    Illinois
    then you risk the chance of mixing dex and green or contaminating the system with tap water
  18. #38 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Jan 2012
    Philadelphia
    yea i know that lol but what problems can mixing different coolants cause?
  19. #39 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Nov 2010
    Illinois
    it causes it to build up in certain spots causing sludge and some other things if someone wants to add something a little more technical
  20. #40 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Jan 2012
    Philadelphia
    yea thats what i herd
  1. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  2. Replies: 7
    Last Post: 12-25-2011, 08:02 PM
  3. Changed lower intake manifold gasket and valve cover gaskets
    By grn97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2011, 08:19 PM
  4. Lower Intake Gaskets
    By predracer04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 03:25 PM
  5. Intake manifold and VC gaskets...
    By bowsox88 in forum General Tech Discussion
    Last Post: 02-15-2011, 07:52 PM
