Thread: Intake manifold and VC gaskets...
Results 1 to 11 of 11
  1. #1 Intake manifold and VC gaskets...
    SE Level Member bowsox88's Avatar
    indiana
    Curious how difficult it is to replace these, the last car i did this to was a 79 cutlass, much more room and less extras to remove to get to it, it looks easy enough but looks can be deceiving.Replacing because i have a small oil leak, i can smell it buring and see it on the front exhaust manifold and have small drips on garage floor at the rear of the engine. Any help and or advice is appreciated. Thanks!
  2. #2 Re: Intake manifold and VC gaskets...
    What do you drive?
    3.1L
    3.4L
    3.8L NA
    3.8L Sc
    IMO the 3.8's are easy. I'd rather burn the other two motors.
  3. #3 Re: Intake manifold and VC gaskets...
    indiana
    Sorry left out some important info there 3.8
  4. #4 Re: Intake manifold and VC gaskets...
    Not to be a dickwad...but would you mind telling us which of the two 3.8's you have?
    We are making progress. Really
  5. #5 Re: Intake manifold and VC gaskets...
    indiana
    Its just a GT so id have to guess the 3.8NA if the 3.8sc is supercharged...im sure i seem pretty dumb at this point but this is all new to me sorry bare with me im making progress
  6. #6 Re: Intake manifold and VC gaskets...
    No worries man..
    The LIM gaskets are relatively easy, the valve covers are also pretty easy. When you do the swap, being NA, I would suggest putting a new UIM on as well. This is because they tend to crack over a lot of heat cycles in the EGR area. This allows cooalnt into the intake and it hydrolocks the motor.
  7. #7 Re: Intake manifold and VC gaskets...
    indiana
    LIM and UIM sorry im assumeing here is lower and upper....and the upper again i assume is the black section on top of the cast intake. Sorry not trying to be difficult just want to be sure i get everything i need before i get into it. Thanks again!
  8. #8 Re: Intake manifold and VC gaskets...
    Minnesota
    When he does the UIM he can use the metal UIM in place of the plastic one. Basically so he won't have the issues again. Unless you are going to top swap it.
    **EDIT** I should have told you it is more work than just buying a new plastic one but if it were me and you are going to keep the car for a while I would do it. But that is just me.
    Example:
  9. #9 Re: Intake manifold and VC gaskets...
    indiana
    Ok i understand all this now and yes i would like to replace the plastic UIM, now my question is where is the best place to get a metal UIM? Napa, Autozone....
  10. #10 Re: Intake manifold and VC gaskets...
    you cant use the metal one unless you bore out the EGR inlet to fit the EGR stove pipe on the L36 LIM. just get a replacement plastic one from your local auto parts store and be done with it.
  11. #11 Re: Intake manifold and VC gaskets...
    Minnesota
    Yeah sorry. There is more work involved than just bolting it on. I don't believe you have to bore the hole out but either shorten the L36 stove pipe or use a L26 stove pipe. An adapter plate for the TB will needed. Also some work on the UIM to account for the PCV and IAT on the L26 UIM.
    If you like doing the work and wanna do it here it is:
    BonnevillePRO.com • View topic - L26 aluminum UIM on L36--Done! With results!!
  1. 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
    By Skillet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2011, 10:51 PM
  2. Exhaust Manifold Gaskets
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 12:22 AM
  3. Which intake manifold is better?
    By ya61x in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2010, 11:51 PM
  4. Intake gaskets
    By HumanWeapon in forum General Tech Discussion
    Last Post: 11-06-2009, 02:52 PM
  5. intake gaskets
    By dpmeeks in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-09-2009, 01:24 PM
