Thread: How to tell if you have the GOOD Lower Intake Manifold gaskets.
Results 1 to 20 of 42
  1. #1
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    When people say they "flushed" out their coolant system to put green stuff in I always hope they did it correctly....
    The system should be drained and replaced with distilled water and a flushing agent.....then the heater should be turned on, run the car like that, repeat flush. Then flush with distilled water at least 2 more times. Also a good idea to change any rubber hoses
    This post brought to you by.....
    For all your 3800 needs:
  2. #2 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Jan 2012
    Philadelphia
    Quote Originally Posted by copgtp View Post
    what can happen if not flushed correctly?
  1. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  2. Replies: 7
    Last Post: 12-25-2011, 08:02 PM
  3. Changed lower intake manifold gasket and valve cover gaskets
    By grn97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2011, 08:19 PM
  4. Lower Intake Gaskets
    By predracer04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 03:25 PM
  5. Intake manifold and VC gaskets...
    By bowsox88 in forum General Tech Discussion
    Last Post: 02-15-2011, 07:52 PM
