Freddy you could just reroute the starter wires from the lock cylinder to your button. Though I would recommend that you also run a NC relay to cut the accessory power while the starter is engaged because that's how the cylinder does it. Doing so makes sure the starter gets as much power as it can without the radio or anything else sucking up much-needed juice.
