Thread: push button ideas
Results 1 to 3 of 3
BoostJunki3 push button ideas 05-14-2011, 06:31 PM
I800C0LLECT Re: push button ideas 05-14-2011, 08:38 PM
stlmo_gtp Re: push button ideas 05-14-2011, 08:48 PM
  1. #1 push button ideas
    Joliet, IL
    so i have this theory.....my alarm has a starter kill relay so that takes care of the security part so i was thinking of taking a toggle switch and hooking it up to the ign wire and accessory wire via a 12v relay so i could power the ign and accessory with no key, then putting a push button on the starter wire before the alarm so when the cars locked the push button wont work....and i will never need a key again.....
    ps. pk3 is already removed on my car....
    think it would work? and wouldnt i have to remove the column lock? how would i do that?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: push button ideas
    Feb 2009
    Virginia
    I've heard of people doing something similar by relocating the ignition with the key already in it. I like it!! Please don't use generic radio shack buttons Use something cool!
    Push Button Switches
    11 is louder than 10!
  3. #3 Re: push button ideas
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Quote Originally Posted by BoostJunki3 View Post
    i have been thinking about doing this for awhile just never got to it, you will have to remove the wheel lock yes, i think to remove it you have to pull off the steering wheel and it should be attached to the back of the steering wheel, or the front of the column? ..that i how it was in a civic i owned not to sure how the set up is on a gp but i wouldn't think it would be much different
  1. Push button for park-lock solenoid in column??
    By BLOWN93LX in forum General Tech Discussion
    Last Post: 04-05-2011, 12:10 PM
  2. Stuck in park! Cant push shifter button!
    By 01STOCKGTP in forum General Tech Discussion
    Last Post: 04-05-2011, 09:23 AM
  3. Push button Start
    By crock in forum General Tech Discussion
    Last Post: 08-31-2010, 04:41 PM
  4. Push Bumper
    By bigboibbp in forum Visual/Body Modifications
    Last Post: 06-20-2010, 07:08 PM
