Thread: Do It Yourself Spectre Intake with Pics
Results 1 to 20 of 31
  1. #1 Do It Yourself Spectre Intake with Pics
    SE Level Member 05CompGMan's Avatar
    Jul 2011
    CT
    I decided to take pics and list the part numbers of everything I bought to put together my Spectre intake. It has been a few years since I had my last GTP and everyone just bought the intakes that were available for big money. I was happy to learn from you guys that putting your own together reaped mostly the same benefits at a fraction of the cost.
    There are of course many ways to put this intake together but so far this seems to be working well for me. This is all installed on my 2005 CompG.
    Parts List:
    (1) 9" Spectre Filter Part# 9732 - Advance Auto
    (1) 45° 3.5" Spectre Polished Aluminum Elbow Part# 9541 - Summit Racing
    (2) 3.5"-3.25" Spectre Coupler Reducers Part# 9551 - Summit Racing
    (1) 3/8 Double Barbed Splicer Part# A-290 - Lowes
    (1) 1/4 Male 1/4 Female 90° Pipe Threaded Elbow Part# A-739 - Lowes
    (1) 3/8 Barbed 1/4 Male Pipe Threaded Adapter Part# A-293 - Lowes
    (1) 1' 3/8 Fuel Line - Advance Auto
    (1) Package Industrial Velcro for PCM - Lowes
    Here you connect the double barbed fitting to the stock 90° PCV rubber elbow to the 3/8 fuel line.
    I drilled and tapped the aluminum elbow to accept the brass fitting for the new PCV hose.
    I used the industrial velcro and positioned the PCM here.
    And fully assembled.
    I know most of you guys can figure these things out for yoursleves but hopefully this will help someone out in the future.
    Thanks!
    Rich
  2. #2 Re: Do It Yourself Spectre Intake with Pics
    St. Cloud, MN
    You could also just bolt the cone right to the end of the MAF and not need anything else and save even more money.
    But, nice write up.
  3. #3 Re: Do It Yourself Spectre Intake with Pics
    Jul 2011
    CT
    Yeah I hear you Dread. I'm partial to a little bit of bling under the hood LOL.
  4. #4 Re: Do It Yourself Spectre Intake with Pics
    Jun 2011
    Detroit, MI
    Good write up with GOOD pictures!
    iLoveSpade
  5. #5 Re: Do It Yourself Spectre Intake with Pics
    Jun 2011
    This will help a lot of people especially the 04+ crowd.
    Good job! Thanks!
  6. #6 Re: Do It Yourself Spectre Intake with Pics
    Nice work! I think this will definitely benefit the 04 +people ...
    Snorlax strikes again.
  7. #7 Re: Do It Yourself Spectre Intake with Pics
    Oct 2011
    Toledo, OH
    Awesome. I have a 9" AEM cone filter due to arrive tomorrow for my weekend project, and this just took all the guesswork right out of it. Except I'll be using Home Depot couplers and pipe lol.
  8. #8 Re: Do It Yourself Spectre Intake with Pics
    Jul 2011
    CT
    Glad the post helped. Good luck with the install.
    05 Comp G - XP Cam // 3.4 // WBS Headers // Spectre Intake // Overkill PCM // PRJ Wires // AL104's
  9. #9 Re: Do It Yourself Spectre Intake with Pics
    Florida
    VERY NICE SETUP. very clean. great info! thank you for helping the community.
    im a porting Nazi! so i have to ask... how far does that PCV adapter stick into the air stream? from my eye ball i figure 1/4" to 1/2" at a min. how about after you drill the hole in the elbow and use the threads to set the threads on it, you take it back out and use a saw to cut it down? so maybe only like 1/16" is past the elbow inner wall?
  10. #10 Re: Do It Yourself Spectre Intake with Pics
    SE Level Member elhomero's Avatar
    Aug 2011
    NJ
    I'm planning to do something like this but hooking up the cone to the MAF like how Dread mentioned. However my father thinks getting rid out stock box setup is a bad idea. His rationale is that since the cone is open, I risk having more stuff and water getting into it and thus getting a check engine light. He always gives me the reason: "If you lived in Florida I can understand, but not here".
    If I can give him a reason besides moar horsepower and getting to enjoy the whine I may be able to sway him. Getting the OK from my dad is a big deal when it comes to cars since he is the one that maintains them in our household.
  11. #11 Re: Do It Yourself Spectre Intake with Pics
    getting enough water into the engine bay high enough to do anything would require a hose.
    the motor ingests water all the time.
  12. #12 Re: Do It Yourself Spectre Intake with Pics
    Florida
    yes water would be over the bumper to reach the filter.... if it is that high... its your fault for driving thru the river and not the intakes fault.
  13. #13 Re: Do It Yourself Spectre Intake with Pics
    Quote Originally Posted by elhomero View Post
    tell dad the inlet for the stock air box is lower than the cone filter you want to put on, and you could get 1 mpg more. if you drive it nice. my car seems to run smoother with a open cone too.
    driving though anything deeper than 6 inches of water you are asking for trouble anyways, the air filter would be my last worry.
  14. #14 Re: Do It Yourself Spectre Intake with Pics
    Jul 2011
    CT
    Quote Originally Posted by Z34Phoenix View Post
    Yes I was planning on cutting it down. It sticks into the intake maybe a 1/2 inch. I don't think it is a real restriction but I'm going to cut it down anyway.
  15. #15 Re: Do It Yourself Spectre Intake with Pics
    Oct 2011
    Toledo, OH
    What size is your Spectre filter outlet set to??
    7"
  16. #16 Re: Do It Yourself Spectre Intake with Pics
    Jul 2011
    CT
    Quote Originally Posted by industrialfish View Post
    The MAF measures about 3.25" so I used the 3.5" on the filter and just tightened it down. You basically remove the smallest rubber insert in the filter.
  17. #17 Re: Do It Yourself Spectre Intake with Pics
    Oct 2011
    Toledo, OH
    Quote Originally Posted by 05CompGMan View Post
    Thanks! My filter is 4in only. Gonna cut a ring off another coupler and use that for a spacer.
    7"
  18. #18 Re: Do It Yourself Spectre Intake with Pics
    Donating Users garagedoorman's Avatar
    Jan 2009
    north georgia
    Sweet write up, clean work. Me Gusta Thanks for taking the time to do it. Will be helpful
  19. #19 Re: Do It Yourself Spectre Intake with Pics
    Oct 2011
    Toledo, OH
    I only used one single 3in coupler between manifold and MAF sensor, with a ring cut off it to be a spacer for the 4in cone. Drilled a hole in the coupler for PCV adapter and used a bit of copper pipe to keep it flush with the inside. The longest part was trying to figure out what to do with the PCM... (zip tied)
    Obviously the SC is louder, but the real surprising part is the noticeable throttle response increase.
    7"
  20. #20 Re: Do It Yourself Spectre Intake with Pics
    Jul 2011
    CT
    Yes the supercharger whine is LOUD under full throttle. Nice job.
  1. Spectre air filter or no?
    By str3etgl0w in forum General Tech Discussion
    Last Post: 06-28-2011, 05:58 PM
  2. before and after intake pics! and vids!
    By 04boostedindyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2011, 11:01 AM
  3. Spectre intake starting problems
    By dakcornholio in forum 04+ Specifics
    Last Post: 04-22-2011, 09:21 PM
  4. K&N vs. spectre
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-04-2010, 12:59 PM
  5. Short Ram Intake from Automat Central with Pics
    By RedLedbetter in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2009, 03:44 PM
