Thread: Do It Yourself Spectre Intake with Pics
Results 1 to 20 of 31
  1. #1 Re: Do It Yourself Spectre Intake with Pics
    Oct 2011
    Toledo, OH
    What size is your Spectre filter outlet set to??
    7"
  2. #2 Re: Do It Yourself Spectre Intake with Pics
    SE Level Member 05CompGMan's Avatar
    Jul 2011
    CT
    Quote Originally Posted by industrialfish View Post
    The MAF measures about 3.25" so I used the 3.5" on the filter and just tightened it down. You basically remove the smallest rubber insert in the filter.
    05 Comp G - XP Cam // 3.4 // WBS Headers // Spectre Intake // Overkill PCM // PRJ Wires // AL104's
  3. #3 Re: Do It Yourself Spectre Intake with Pics
    Oct 2011
    Toledo, OH
    Quote Originally Posted by 05CompGMan View Post
    Thanks! My filter is 4in only. Gonna cut a ring off another coupler and use that for a spacer.
    7"
  1. Spectre air filter or no?
    By str3etgl0w in forum General Tech Discussion
    Last Post: 06-28-2011, 05:58 PM
  2. before and after intake pics! and vids!
    By 04boostedindyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2011, 11:01 AM
  3. Spectre intake starting problems
    By dakcornholio in forum 04+ Specifics
    Last Post: 04-22-2011, 09:21 PM
  4. K&N vs. spectre
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-04-2010, 12:59 PM
  5. Short Ram Intake from Automat Central with Pics
    By RedLedbetter in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2009, 03:44 PM
