Quote Originally Posted by brandonl2000 View Post
Furthermore, it may help to take those two little weird nuts off of the bracket holding the cruise control module on as it may get in the way. When I done it, I loosened those two nuts on the side and pulled up on the whole motor itself so that it allowed room to pull the ebcm straight off and then up. Don't pull it at an angle because those solenoid valves are rather fragile
I will make sure to do this when I re-install the sucker.
