I replaced a 2007 base model Grand Prix EBCM from a $20 junk yard same year part and it worked with no reprogramming. Code was a c0090
Interesting info I found that I'd like to pass along about the C0090 ABS code says module must be replaced for this code:
A L L Diagnostic Trouble Codes ( DTC ): C Code Charts
C0090
DTC C0060-CO095
Circuit Description
The inlet and outlet valve solenoid circuits are supplied with battery power when the ignition is in the ON position. The EBCM controls the valve
functions by grounding the circuit when necessary.
Conditions for Running the DTC
^ The DTC can set anytime the ignition switch is in the ON position.
^ The DTC can set when the vehicle speed is greater then 6 km/h (4 mph) and the brake pedal is not applied.
^ The DTC can set when the vehicle speed is greater then 15 km/h (9 mph) and the brake pedal is applied.
Conditions for Setting the DTC
The DTC will set when the EBCM detects one of the following internal to the EBCM only:
^ An open in the solenoid coil or circuit.
^ A short to ground in the solenoid coil or circuit.
^ A short to voltage in the solenoid coil or circuit.
Action Taken When the DTC Sets
It equipped, the following actions occur:
^ A malfunction DTC is stored.
^ ABS/TCS is disabled.
^ The ABS/TCS indicators are turned on.
Conditions for Clearing the DTC
^ The condition for the DTC is no longer present and you used the scan tool Clear DTC function.
^ The EBCM automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.
Diagnostic Aids
The solenoid valve circuit and the solenoid coil are internal to the EBCM. No part of the solenoid circuit is diagnosable external to the EBCM. The
DTC sets when there is a malfunction in the solenoid circuit internal to the EBCM only.
Test Description
The numbers below refer to step numbers on the Diagnostic Table.
2. This step determines if the DTC is current.
