Thread: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 91
  1. #61 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Jan 2015
    United States
    Did I read your posts correctly that if I have an 01 GTP and want to try a used module first that I don't need to worry about the 5 rule thing? I just need to stay GTP to GTP?
  2. #62 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Kemmerer, Wyoming
    I'm not sure what the 5 rule thing is, but there are several compatible years that you can use to replace your abs module. another option is to get the electronic portion rebuilt, its like 160 and www.modulemaster.com out of moscow idaho does it. you just have to make sure your module is what is causing the problem because modulemaster cant test the module before or after.
  3. #63 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Grand Rapids, MI
    Quote Originally Posted by sparkydog View Post
    In theory because your year model is compatible. But honestly man, I took an ebcm from the same year and model as my 03 and paid attention to the bosch serial number and a used one did not work for me. But I've heard of times when it does work, so if the cost of a used one is little to nothing I say go for it.
    Hands down, www.modulemaster.com is the way to go though.
  4. #64 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Cheapabs.com is also another option
    04 Comp G.
  5. #65 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    bought a used unit from ebay because mine wouldn't communicate with a scan tool. the used one i bought was supposedly from a 2000 gtp which is what i have. the numbers were different than the new used one. i couldn't find the #88894774 on mine or the one i bought , .. installed the new, used one ...still got abs , traction control and ses lights on. haven't tried scanning it yet.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  6. #66 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    There's a guy on eBay they rebuilds them for $40-50 might be worth just having your checked out and repaired and get your money back for the other one you brought.
    04 Comp G.
  7. #67 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Jan 2015
    United States
    I used this guy to fix my ABS module on an '01 GTP. It worked great!
  8. #68 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Yoga city
    There are a lot of great services out there to rebuild them if your not comfortable doing it yourself.
  9. #69 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Dec 2014
    Maryland
    it's too late for a return. only got 30 days and i took too long to get it installed to determine it didn't help. just realized i didn't unhook the battery during removal / installation... don't know if that could have affected it...someone suggested a fuse or relay. looking in the owners manual , all i see abs related is a 10 amp fuse marked ac clutch, abs ingnition. the ac doesn't work , could this fuse being blown stop a scan tool from communicating with the ebcm ? also i seen ground wire as a possible culprit. anyone know where the ground is ?
  10. #70 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Dec 2014
    Maryland
    good news. went and had a scan redone (with the same snap on) and it did communicate this time. PROGRESS !!!
    now it's throwing the c0035 code , which from what i gather is the left front wheel speed sensor. i've already replaced both front hub assemblies with timkens , so now HOPEFULLY a new wire harness will solve the problem . i'm replacing both just for good measure.
  11. #71 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Yoga city
    Seal them harnesses up real good or your just looking into future issues.
  12. #72 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Dec 2014
    Maryland
    Quote Originally Posted by jteske88 View Post
    would you suggest something other than the shrink tubing ?
  13. #73 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Dec 2014
    Maryland
    well i replaced the left front harness because it was throwing the c0035 code. started car abs/tc lights still on. rescanned and it gave the c0040 code ...right front...replaced right harness and now i have no abs lights and the TC works as it should ...YAY..
  14. #74 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Jun 2015
    Iowa
    Are there any threads out there that discusses DIY repair?
  15. #75 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Dec 2014
    Maryland
    Quote Originally Posted by owi racing View Post
    what exactly are you trying to repair ?
  16. #76 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Jun 2015
    Iowa
    The EBCM
  17. #77 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    Dec 2014
    Maryland
    The EBCM
    not that i'm aware of...try youtube. i found a used one on ebay for a hundred bucks...it worked
  18. #78 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    I replaced my ebcm few months ago no lights everything works as should. I replaced the power steering pump with one from O'Reilly 3 times while the ebcm was bad and the rack also.. now street the ebcm I have no lights but power steering is stiff and noisy at low speeds under 20mph, could the ebcm messed with the pump or should I try another pump??
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  19. #79 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    SE Level Member Metal Links's Avatar
    Dec 2013
    NJ
    I have an 04, so I can just try pulling a EBCM from any 99+ as long as there's no 5 in the serial number, or can I only pull 04+? I will check my EBCM number tomorrow, and I could take pictures if anyone needs a guide made.
    I have C0050, C0095, already replaced my hub and wiring.
  20. #80 Re: EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Link says all 98-07. That's where I had mine repaired. Matt fixed it and got it back to me right away.
    http://www.cheapabs.com/vrpontiac.html
  1. Body Control Module?
    By roxie in forum General Tech Discussion
    Last Post: 06-29-2011, 12:15 PM
  2. 1998 GTP Electronic Braking/Traction Control Module
    By Luvgrandprix in forum General Tech Discussion
    Last Post: 04-28-2011, 10:24 AM
  3. 1998 GTP Electronic Braking/Traction Control Module
    By Luvgrandprix in forum Introductions/Noob Questions
    Last Post: 04-23-2011, 11:43 AM
  4. Does anyone know where i can find a 3rd brake light replacement?
    By Stiffler419 in forum General Tech Discussion
    Last Post: 09-02-2010, 02:27 PM
  5. 5th brake hose -hard line solution ~$6
    By alacran in forum How To Write-Ups/Tech Tips
    Last Post: 10-02-2008, 08:18 PM
