Thread: How to change coolant elbows
Page 5 of 5 FirstFirst ... 345
Results 81 to 93 of 93
  1. #1 Re: How to change coolant elbows
    that sloshing sound is air in the heater core, take both heater hoses off the alt bracket, then put a garden hose to one of the hoses and flush the core. then flush your coolant.
    id do the elbows first, then flush the core, then the coolant flush to new.
  2. #2 Re: How to change coolant elbows
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Gonna be going this soon and have a couple questions. If replacing the plastic elbows with aluminum ones would using RTV so assure no o-ring leaks in the future be a bad idea? I don't see having to replace the aluminum ones ever so I wouldn't have to worry about scraping off old RTV. My other question is I will refill for Dexcool for the time being but in the summer will do a whole coolant system flush. There's no reason I should do the flush now right?
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  3. #3 Re: How to change coolant elbows
    Doing the replacement is the same. Asking my opinion it is a bad idea to RTV them. The o-ring seals and seals well if you do the job right. elb
    Aluminum elbows.. most of you weren't around for the elbow that GM cast into the belt tension/alt bracket. Reason why they went plastic is because you'd break the timing cover if you pulled it off wrong. I feel that the aluminum ones are going to corrode and cause more issues after they've been in for years. Plastic ones distort because guys don't follow the write up that we are posting in.
    I wouldn't use RTV and personally.. I also never had a plastic one blow out after the first. Once my first one distorted..I realized I had put it in with pressure on it and it showed me what doing the job poorly resulted in.
  4. #4 Re: How to change coolant elbows
    Buffalo, NY
    Bill, so you're saying to just get the plastic ones then? I had the elbows replaced 3 maybe 4 years ago and it's leaking again already which was why I was thinking aluminum this time around. I'll skip the RTV but should I get the delco o-rings?
  5. #5 Re: How to change coolant elbows
    If you follow the write up.. you should be fine.
    Lube the rings so they don't get hurt going in. Wiggle elbows as you tighten so they don't end up with pressure pushing them into a 45 degree and ... that's about all there is to it. If you want to go aluminum.. do it. I wouldn't put any additional value to them vs the plastic though. Especially if you have to pull things apart later and you pull the wrong way and break a timing cover. That's...what the difference in plastic vs aluminum would be.
  6. #6 Re: How to change coolant elbows
    Buffalo, NY
    Sounds good thanks for the help
  7. #7 Re: How to change coolant elbows
    i pulled my lim off of a new metal elbow. i had new o rings i installed from the lim kit and reused the elbow. came off like nothing. still on there today no rtv, just clean the holes good, use sand paper if need be, oil the o rings and slide em in.
  8. #8 Re: How to change coolant elbows
    Buffalo, NY
    New question. If I top off the coolant would it be safe to drive the car about 10 miles to my parents garage?
  9. #9 Re: How to change coolant elbows
    depends on how fast its leaking out and if it will over heat or not.
    this is a road side repair for many people.
  10. #10 Re: How to change coolant elbows
    SWPA
    This, I did it in a gas station parking lot when mine split a few years back.
  11. #11 Re: How to change coolant elbows
    Buffalo, NY
    I plan on draining and flushing the radiator at the same time which I can't do in my f'd up driveway. I'll keep a bottle of coolant with me on the drive and hope for the best. It seems to be a slow leak from what I can tell.
  12. #12 Re: How to change coolant elbows
    just refill with water, why toss money in the street, literally lol
  13. #13 Re: How to change coolant elbows
    Buffalo, NY
  1. Need to replace coolant elbows
    By Posty101 in forum Engine
    Last Post: 06-02-2011, 02:22 PM
  2. coolant elbows
    By noreasonwhyy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2010, 05:56 PM
  3. How do you replace the coolant elbows?
    By Mercenary in forum General Tech Discussion
    Last Post: 07-19-2010, 06:50 PM
  4. Coolant elbows
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 12-01-2009, 11:58 AM
  5. Coolant Elbows for 2000 GTP
    By nickbuol in forum General Tech Discussion
    Last Post: 07-21-2009, 10:51 PM
