Thread: Removing Supercharger Snout Oil
Results 21 to 40 of 44
  1. #21 Re: Removing Supercharger Snout Oil
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    What is the recommended change intervals for the S/C oil?
  2. #22 Re: Removing Supercharger Snout Oil
    Wichita, KS
    Depends on your driving habits IMO.
    GM kinda says to never change the fluid since its self contained, and "maintenance free" they are merely looking forward to selling and installing a complete new supercharger for you later down the road.
    Some say every 30K some say every 50K some say every 100K.
    With me, its yearly regardless.
    With the GF's GTP its yearly as well, but her GTP is her daily driver, so she rakes on at least 20K maaaaaaaaaaaaaybe.
    ~F~
  3. #23 Re: Removing Supercharger Snout Oil
    Jul 2008
    Tulsa
    Awesome, thanks for the info...
    2004 White GTP...Stock Stock Stock...Soon...3.0 ZZP MPS, ported blower, Pacesetter Coated Headers, FWI, Tuned PCM, VS cam, 105# springs, JP timing chain, whisper resonator and custom exhaust...My next goal(after I rebuild my savings)... 2.5" IC, 2.6 pulley, XPZ Cam, S3 heads, and a tranny....
  4. #24 Re: Removing Supercharger Snout Oil
    SE Level Member NickT'sGTP's Avatar
    Cedar Rapids, IA
    I also do mine yearly. I just checked the s/c oil in a friend of mines Regal GS last night, and hers was BLACK. She has damn near 200K miles on the GS and I'm pretty sure it's never been done.
    Oh, BTW I have s/c oil remover kits as well, if anyone is interested.
    1998 Grand Prix GTP - 12.699 @ 108.84 - 1.931 60 ft - Gone.... but not forgotten....
    2005 Impala SS - 14.790 @ 94.35 - 2.262 60 ft - 100% Stock
  5. #25 Re: Removing Supercharger Snout Oil
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Where can I buy a oil remover?
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  6. #26 Re: Removing Supercharger Snout Oil
    Wichita, KS
    ^ huh?
    What are you trying to clean or degrease here?
    ~F~
  7. #27 Re: Removing Supercharger Snout Oil
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    well i'd like to clean mine. im at 56k and never done it....what type of oil and how much do u put back in?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  8. #28 Re: Removing Supercharger Snout Oil
    Saraland Alabama
    it's GM supercharger oil, and it's about 1.5 bottles (although my dealer says 1 bottle)
  9. #29 Re: Removing Supercharger Snout Oil
    Bartlett, IL
    Quote Originally Posted by Zef_66 View Post
    I went to walmart and bought a turkey baster for like $1. Then stopped at the auto parts store and got a foot of rubber hose that would fit over the end of the baster and still small enough to fit into the snout hole. That was less than $1. Works great!
    Im gonna do that
    How To: E-Brake Pwn
  10. #30 Re: Removing Supercharger Snout Oil
    Wichita, KS
    Quote Originally Posted by offroadfury6 View Post
    I recommend using and only using GM Supercharger oil.
    GM Part Number = 12345982
    Those are a 4oz. bottle. You will need two bottles to fill your M90.
    I have never had a GenIII or GenV M90 take anything less than 2 whole bottles unless you under fill it.
    The fill line is the bottom of the threads of the fill plug hole in the snout.
    Therefor, 8 oz. give or take a little is what they normally take since the measurements on the bottles from GM are not always perfect. Some times you have some extra...some times you need some more.
    ~F~
  11. #31 Re: Removing Supercharger Snout Oil
    Cedar Rapids, IA
    Yeah, just a few weeks ago I had to change out my s/c oil, and it took me both bottles, and it barely touched the bottom of the threads. That stuff smells good.
  12. #32 Re: Removing Supercharger Snout Oil
    Aug 2008
    Fayetteville, NC
    ill check wid GM dealer next week on it, no time rite now...
  13. #33 Re: Removing Supercharger Snout Oil
    Spring, TX
    What can be used as a temporarary oil to top it off while I wait for my dealer to get the GM oil? I'll change it after the GM stuff comes in, but I need to top it off now.
  14. #34 Re: Removing Supercharger Snout Oil
    in a house
    Quote Originally Posted by VinceJE View Post
    Nothing, you will have to wait for the sc oil or try a different dealer. Dont put nothing but supercharger oil in it
  15. #35 Re: Removing Supercharger Snout Oil
    Spring, TX
    I have to drive it while I'm waiting. No other dealer has it in stock either. I'll be putting about 500miles on it before the dealer has the GM stuff in. It's probably about 2/3 full. I think the fill plug seal is leaking. I just want to top it off for that 500miles & then I'll change it all out. Surely there is something that can be used in a pinch. ???
  16. #36 Re: Removing Supercharger Snout Oil
    in a house
    Well if you're really stuck, take the s/c belt off. It will be a turtle but atleast you wont be screwing it anymore. Dont put anything BUT s/c oil in their even if its a small amount. Pretty easy to pop the belt off
  17. #37 Re: Removing Supercharger Snout Oil
    Donating Users
    Plainfield, IL
    Quote Originally Posted by silverstreak View Post
    x2 i had to drive with my sc belt off one time because i had a bad idler pulley....the L67 is an out of breathe pig without boost lol
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  18. #38 Re: Removing Supercharger Snout Oil
    Wausau, WI
    Quote Originally Posted by GTP00Matt View Post
    Empty windex bottle here, used the sprayer to pump it out and the bottle to hold the old oil.
    wow.........that is awesome........I never would have thought of that.
  19. #39 Re: Removing Supercharger Snout Oil
    Wausau, WI
    has anyone ever emptied out the SC oil and cleaned it out with some type of cleaner before inserting new oil? Is there ever any type of build up or gunk in there......sludge or anything?
  20. #40 Re: Removing Supercharger Snout Oil
    Here we go
    Quote Originally Posted by TLSheff
    Quote Originally Posted by BillBoost37
    Yeah, I was talking smack about you today.
    Still got the original pics of that TSB or maybe the number on the sc oil and mobil 1? I got GM ESI and can maybe search on it to post the original document.
    LOL Always talkin smack about me it seems... jerk
    ya I got the original scans in my FB
    http://i93.photobucket.com/albums/l79/tlsheff/Work%20lol/SuperchargerOilPage1.jpg
    http://i93.photobucket.com/albums/l79/tlsheff/Work%20lol/SuperchargerOilPage2.jpg
    Remember they are older documents but I called and verified thru GM that they still stand by these documents as replacements for the fluid. You just need to replace the fluid more often, as you would expect with motor oil.
  1. Report: Motor Oil In The Supercharger Snout
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2008, 07:32 PM
