Awesome, thanks for the info...
I also do mine yearly. I just checked the s/c oil in a friend of mines Regal GS last night, and hers was BLACK. She has damn near 200K miles on the GS and I'm pretty sure it's never been done.
Oh, BTW I have s/c oil remover kits as well, if anyone is interested.
Where can I buy a oil remover?
well i'd like to clean mine. im at 56k and never done it....what type of oil and how much do u put back in?
I recommend using and only using GM Supercharger oil.
GM Part Number = 12345982
Those are a 4oz. bottle. You will need two bottles to fill your M90.
I have never had a GenIII or GenV M90 take anything less than 2 whole bottles unless you under fill it.
The fill line is the bottom of the threads of the fill plug hole in the snout.
Therefor, 8 oz. give or take a little is what they normally take since the measurements on the bottles from GM are not always perfect. Some times you have some extra...some times you need some more.
~F~
Yeah, just a few weeks ago I had to change out my s/c oil, and it took me both bottles, and it barely touched the bottom of the threads. That stuff smells good.
it's GM supercharger oil, and it's about 1.5 bottles (although my dealer says 1 bottle)
ill check wid GM dealer next week on it, no time rite now...
What can be used as a temporarary oil to top it off while I wait for my dealer to get the GM oil? I'll change it after the GM stuff comes in, but I need to top it off now.
I have to drive it while I'm waiting. No other dealer has it in stock either. I'll be putting about 500miles on it before the dealer has the GM stuff in. It's probably about 2/3 full. I think the fill plug seal is leaking. I just want to top it off for that 500miles & then I'll change it all out. Surely there is something that can be used in a pinch. ???
has anyone ever emptied out the SC oil and cleaned it out with some type of cleaner before inserting new oil? Is there ever any type of build up or gunk in there......sludge or anything?
Yes you did.
the bulletin is old, technically says for the M62 superchargers, but the oil is for the gears, coupler, and bearins in the snout... same as the M90s. Same fluid used for both as well. So I called tech support for GM personally and asked if it stands for the M90s and they said it can be but you would have to replace it alot sooner.
As I said, we've had debates over it, some go by it, some call it blasphemy. Its up to you, keep it maintained and you shouldn't have any problems.
Since that was posted 7/22/2008 I would imagine anything he had "percolating" is not good anymore. He's barely on here anymore as it is, I doubt if he is still trying to come up with a new fluid.
Recommended is the GM supercharger fluid, if you need cheaper buy it from Intense-racing.com or some other vendor online and order it, or do like what was said by Bill & Myself and there is a bulletin (highly debated by some) that says you can use Mobil1 5x30 oil in place, you just have to change it every 10k(ish) instead of the 30k/50k/100k/1yr people normally do.
