Thread: How to fix a dim hud 97-03
Results 1 to 20 of 30
  1. #1 How to fix a dim hud 97-03
    Remove the trim panel over the HUD and remove the HUD itself.
    Remove the 4 T15 screws holding the HUD together at the four corners
    Looking inside we see the circuit board, remove the two wire brown connector from the board
    Remove the ribbon cable from the board
    Gently pull back the two tabs being pointed to by the pens and lift that side of the circuit board.
    Now with your circuit board out, find the photocell. It is the round sliver item with a glass on it.
    Find the two solder dots holding the photocell to the circuit board on the other side.
    Using a soldering iron (smallish tip) touch each of the two soldering points for the photocell to reflow the solder on them. Reflowing is heating them up to allow the solder to liquify again and make a good connection.
    Reassemble. If the issue was a loose photocell, your problem should now be solved.
  2. #2 Re: How to fix a dim hud 97-03
    dup?
  3. #3 Re: How to fix a dim hud 97-03
    Could be. I haven't looked and Nick said flood away with write ups if I had them.
  4. #4 Re: How to fix a dim hud 97-03
    true enough
  5. #5 Re: How to fix a dim hud 97-03
    Jul 2011
    bristol,va
    thanks alot il try that, is clips holding it on the dash? thanks
  6. #6 Re: How to fix a dim hud 97-03
    Akron Ohio
    What if you remove the photocell?
  7. #7 Re: How to fix a dim hud 97-03
    Quote Originally Posted by JoshsGTP View Post
    I think you'd have to jump the circuit. However I'm not suggesting anything other than a fix that others have shown to work well.
  8. #8 Re: How to fix a dim hud 97-03
    Never Never Land
    Just to clarify we don't have to add more solder do we? Just reheat what's already there so it can melt and get a better contact?
  9. #9 Re: How to fix a dim hud 97-03
    The Boss Iceman6669's Avatar
    Jun 2011
    Thnx... I just did it and it worked Great.... Very easy to do...
    2011 F-150 Yote powered
  10. #10 Re: How to fix a dim hud 97-03
    SE Level Member natejames99gtp's Avatar
    st.cloud minnesota
    thanks for the help, mine didnt work at all before, and it only took 15 mins of messin around and 5 mins to put back together and its done
  11. #11 Re: How to fix a dim hud 97-03
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    How do I get the trim piece off without breaking my dash?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  12. #12 Re: How to fix a dim hud 97-03
    pull slowly popping the clips one by one. I've pulled a couple out and wasn't very careful and didn't break anything.
  13. #13 Re: How to fix a dim hud 97-03
    Oct 2011
    Michigan
    alright on my first attempt i went slow and cracked it a little bit
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Use the correct trim panel remover to avoid breaking the panel.
    Sent from my DROID RAZR using Tapatalk 2
    For all your 3800 needs:
  15. #15 Re: How to fix a dim hud 97-03
    Oct 2011
    Michigan
    you mean a j 38778 tool?
  16. #16 Re: How to fix a dim hud 97-03
    Oct 2011
    Michigan
    used the proper tool still eened up breaking clips, got the 4 scews to get the HUD out lony the top houseing would come out couldnt get it out at all
  17. #17 Re: How to fix a dim hud 97-03
    Usually a trim panel tool helps. Sometimes the plastic is old and brittle.
    On the screws, look at the body of the hud and find the 7mm bolts/phillips heads on the side... I think there might be one in the front too. Those get the body out.
  18. #18 Re: How to fix a dim hud 97-03
    SE Level Member 2000gtpbt's Avatar
    Mar 2012
    Alexandria, MN
    Thanks for the write-up on this. HUD went out last week and got it working and all put in today. A+
  19. #19 Re: How to fix a dim hud 97-03
    May 2012
    Grand Forks, ND
    What if its not the photocell? Buy a new one? Lol
  20. #20 Re: How to fix a dim hud 97-03
    Test for power, ensure it's not a fuse. Then I'd say maybe a different one.
