Thread: Removing Supercharger Snout Oil
Results 1 to 20 of 44
  1. #1 Re: Removing Supercharger Snout Oil
    SE Level Member hotshot's Avatar
    R.I.
    Is that all thats involved in changing the sc oil? I need to do mine because I have no idea if it has ever been changed. How much oil is in there? do you just take out what you can then put the same amount back in? sorry for the noob questions but I am new to superchargers.
    98 GTP - slp powerflo cat back, built tranny, AP104s, homemade FWI and intense 180 stat.
  2. #2 Re: Removing Supercharger Snout Oil
    Wichita, KS
    ^ its easy. Smelly...but easy.
    General rule, if you don't know...then it has never been changed most likely.
    How much is in there?
    There is only about 8oz. Two 4oz. bottles of the GM supercharger oil is all you need to fill it. Some times more, sometimes less. Any GM dealership should have this in stock most the time. Its usually about $7.00 or $8.00 a bottle.
    You have the right idea, take out, or in your soon-to-be-case SUCK out all you can, and refill to the bottom of the threads where the plug goes. Some times direct sun light or a flash light is a good aid in this to see down in there good. You cannot really over fill it, but you can under fill it. As long as its to the bottom of the threads of the fill hole, your good.
    Comes out pretty smelly, so don't get it on you or your cloths. Normal color is dark ice tea looking color to black at times. But it goes in perfectly clear brand new from the bottle.
    What I do is suck it out, and transfer it to another bottle that has a screw on seal able lid to store the oil in. I use old rubbing alcohol bottles myself. At any given time, i could have about 3 or 4 of them filled up.
    ~F~
  3. #3 Re: Removing Supercharger Snout Oil
    SE Level Member NickT'sGTP's Avatar
    Cedar Rapids, IA
    I use a 60 ml syringe and a 10 fr. suction catheter. Works like a charm.
    1998 Grand Prix GTP - 12.699 @ 108.84 - 1.931 60 ft - Gone.... but not forgotten....
    2005 Impala SS - 14.790 @ 94.35 - 2.262 60 ft - 100% Stock
  4. #4 Re: Removing Supercharger Snout Oil
    R.I.
    Has anybody used the intense racing supercharger oil? I have been buying a few things from them and they seem to know their stuff. They have an 8 oz bottle for the same price as the 4 oz GM oil and they say its chemicly exact and they even get it from the same manufacturer.
  5. #5 Re: Removing Supercharger Snout Oil
    Wichita, KS
    Quote Originally Posted by hotshot View Post
    Could not tell you honestly.
    They probably do the same thing ZZP does and buy the oil by the 55 gallon barrel in bulk, and for some odd reason don't hike up the price cause they are getting a price break buying in bulk like that. Or calling it their "own special mixture" and charing more etc.
    I personally use, run and install in all my blowers official GM SC oil. For now. The "for now" was a hint to everyone else that something is brewing here locally.
    ~F~
  6. #6 Re: Removing Supercharger Snout Oil
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    What is the recommended change intervals for the S/C oil?
  7. #7 Re: Removing Supercharger Snout Oil
    Wichita, KS
    Depends on your driving habits IMO.
    GM kinda says to never change the fluid since its self contained, and "maintenance free" they are merely looking forward to selling and installing a complete new supercharger for you later down the road.
    Some say every 30K some say every 50K some say every 100K.
    With me, its yearly regardless.
    With the GF's GTP its yearly as well, but her GTP is her daily driver, so she rakes on at least 20K maaaaaaaaaaaaaybe.
    ~F~
  8. #8 Re: Removing Supercharger Snout Oil
    GT Level Member 40th GP's Avatar
    Utah
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    Has your brew finish percolating?
  1. Report: Motor Oil In The Supercharger Snout
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2008, 07:32 PM
