Thread: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
Page 4 of 4 FirstFirst ... 234
Results 61 to 76 of 76
  1. #61 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    SE Level Member BlackGTP01's Avatar
    Nov 2014
    Reno
    Awsome, Thanks for the fast response, I appreciate it! Back to work!
  2. #62 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Apr 2015
    Brooks
    Awesome write up for a noob to ingest!!! I have this swap planned and was wondering if there is any benefit to having a whole car for the swap? I scored an GT with 137000km on it and drove it to my storage. It lost an argument with a deer!! I now have a Gen V blower and a lot of other parts for my 2001 GTP! I will be asking a lot of questions down the road as I do this swap. Thanks and keep the write ups coming!!!!
  3. #63 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Buffalo
    Did anyone mention yet if a gen3 full size intercooler core will still work with a gen5 blower?
  4. #64 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by crazyguy03 View Post
    It works.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  5. #65 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Buffalo
    Buddy of mine found a gen5 , I couldn't give a solid answer ; I've only ever machined a lower manifold to make it fit but used the correct core
  6. #66 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    ​nice thread, im still procrastinating on doing my intercooler setup
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  7. #67 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Sep 2015
    ohio
    how do i stick this?
  8. #68 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    GT Level Member aligater's Avatar
    london ontario canada
    You got to lick it, before you stick it, gotta get it hot and wet so we can kick it
  9. #69 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Mar 2013
    Spring, TX
    I'm curious as to why it says here that you can only utilize the Gen V's evap sensor if you use an l67 TB, why could I not use the Gen V evap with a N* TB? Has anyone here done this?
  10. #70 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Because the throttle linkage hits the sensor on the N*.
  11. #71 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Mar 2013
    Spring, TX
    Can't you flip the tb though? Or will it still hit?
  12. #72 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    I had a bonne and didn't need to flip. Plus I had the older Evap..so I didn't try to flip. Likely you can.
  13. #73 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Yes flip the N* and it works
  14. #74 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Feb 2015
    california
    Aftermarket hoods like SD should have plenty of clearance right? With a 2" IC will i have clearance issues like needing to flip the TB or use cradle spacers?
  15. #75 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    GT Level Member 0069GTP's Avatar
    Oct 2014
    Western NC
    Quote Originally Posted by silenthaven View Post
    http://www.grandprixforums.net/threa...earance-issues
    Take a look at this thread. I have the F1 hood from Stinger Fiberglass, bought it last year at the Charlotte Auto Fair. But I decided to wait until after I both lowered my car and got my intercooler on before checking out the hood. I think that the issue will be where they have made the "Ram Air" duct in the hood that can be opened up at the air box. My hood needs body work where the upper and lower pieces where put together anyway, so I figured that if it needed to be notched and re-glassed that it would be cheapest and easiest to do all at once.
  16. #76 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Kemmerer, Wyoming
    let's bring this back, is there an easy way to know if the gen 3 blower is maxxed out? my car feels faster with the 2.8 pulley than it does with the 2.6.
  1. Replies: 716
    Last Post: 01-06-2018, 05:44 PM
  2. Eaton M90 Gen V supercharger problems
    By 05GTPcmpg in forum Off Topic Discussion
    Last Post: 06-04-2011, 11:20 PM
  3. Need pcv help for IC'd GenV swap
    By 00gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 04:44 PM
  4. Can I install eaton m62 supercharger on L36 engine?
    By SBB in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2010, 01:15 PM
