Thread: Need pcv help for IC'd GenV swap
Results 1 to 12 of 12
  1. #1 Need pcv help for IC'd GenV swap
    Jan 2009
    Michigan
    I'm going to be doing a GenV swap on a WBS Gen3 IC and Gen3 LIM with N* TB. I'm running a breather now with the current Gen3 setup, but want to get rid of it and have functional PCV with the GenV. I've read through many threads and think I have the right idea on how to do it. Please let me know if I'm on the right track.
    The WBS core has holes in the back by the PCV valve, so first thing would be to drill a hole in the LIM to match up with the hole in the bottom plate.
    Then, run a hose from the vertical nipple on the back of the GenV to a fitting in the N* adapter plate (after TB blade).
    Then, tap the side of the front valve cover, and run a hose from that fitting to the brass fitting in the N*TB (after MAF, before blade).
    Will this setup work while being able to keep the PCV valve in the blower like stock? Should I run a catch can from the rear or is there not a whole lot of oil coming from the nipple in the blower? Thanks for any advice
  2. #2 Re: Need pcv help for IC'd GenV swap
    Jan 2009
    Michigan
    Just realized the PCV port in the back of the genV is for FRESH air. Could I still use this if the PCV holes in the front of the LIM are blocked?
    If so then it would go...
    Hole drilled in rear of lim by pcv valve for the ic core
    Rear (or front?) valve cover tapped and hose ran to N* adapter (post maf and tb blade) for positive vacuum
    Hose ran from genV pcv port to N* pcv fitting (post maf, pre tb blade) for fresh air.
    Again would the stock pcv valve be functional?
  3. #3 Re: Need pcv help for IC'd GenV swap
    1. your trying to put a gen V blower on a genIII IC core/LIM? might wanna check your math on that one...
    2. why dont you just run a breather and call it a day? to each their own but i think if you make all the new routing your just giving yourself more things that can malfunction (leak) in the long run... and correct me if im wrong but i dont think theres any huge side effects from running a breather...
  4. #4 Re: Need pcv help for IC'd GenV swap
    Jan 2009
    Michigan
    Quote Originally Posted by gtpsleeper View Post
    1. your trying to put a gen V blower on a genIII IC core/LIM? might wanna check your math on that one...=
    whats to check? its been done numerous times.... maybe you're thinking of a genIII blower on a GenV core/LIM, cuz that doesnt work. And its known that a functional pcv is better than a breather. Reasons I want to get rid of the breather are to make tuning more consistent, get rid of the milky crap that builds up in the breather because of the moisture, and it helps the rings seal better.
    I guess I could sell my core and get a new zzp one, but dont really want to put the money into it. Rather make it work with what I have.
  5. #5 Re: Need pcv help for IC'd GenV swap
    I hope someone else comes in on this because I dont think you can do what you are trying to with the genV to gen III... i could be wrong not saying you are or anything...
    but on the pcv note... ive never had "milky crap" on my breather and its not going to affect the rings sealing thats got more to do with engine temp...
    ask a guy with a tuner though who would know but again I dont think it makes a difference in the tune IF you tune the car with it on there...
    just my .02... i hope someone comes in with some answers for both of us...
  6. #6 Re: Need pcv help for IC'd GenV swap
    Jan 2009
    Michigan
    ClubGP Message Forum troubleshooting
    It's not the most ideal way to set it up, as you do waste ~7/8" of the blower since its extended to the left more than the Gen3, but people have reported gains over a fully p&p Gen3. Some guys think there's only about 5hp lost over setting it up this way, rather than using a GenV core.
  7. #7 Re: Need pcv help for IC'd GenV swap
    wow... I NEVER knew that man im glad i read that!!
  8. #8 Re: Need pcv help for IC'd GenV swap
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    im doing a gen 5 top swap on my car as well got any info for me u can happily exchange haha
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  9. #9 Re: Need pcv help for IC'd GenV swap
    Cliff..post pics of what you have.
  10. #10 Re: Need pcv help for IC'd GenV swap
    bill everything in my sig is what i have im deleting the egr in the next week and building my own fwi set. basically im gettin the gen 5 blower l32 lim and n* tb for a killer deal. going to talk to intense about the tune tomorow for the n* just tryin to see if theres anything else. now im deploying to iraq in a couple months and thats gona pay for the trans when i nuke it beings its still the stock trans and has 210000 miles on it
    SMGPFC #77
  11. #11 Re: Need pcv help for IC'd GenV swap
    Reason I say take pics is .. the WBS core I used had the PCV holes
  12. #12 Re: Need pcv help for IC'd GenV swap
    Mercer, Pa
    How to get PCV TO WORK
    http://www.grandprixforums.net/how-g...tml#post536565
    GEN 5 on gen 3 intercooler will work. Gen 3 on gen 5 intercooler will not work.
    I got milky crap when I ran without a PCV.
  1. L32 swap or GenV swappers please help..
    By Myprixxx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2010, 02:14 AM
  2. Want to know what a GenV sounds like? (Video)
    Last Post: 08-03-2008, 11:15 AM
  3. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
