Thread: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
Results 41 to 60 of 76
  1. #41 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Mar 2013
    Spring, TX
  2. #42 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Banned
    Jan 2013
    Colorado
    great write up, subbed
  3. #43 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Kemmerer, Wyoming
    to run the N* throttlebody on a gen 5 what custom work do you need to do? also is there any benefit to porting the gen 5 lower intake manifold
  4. #44 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Great write up......
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  5. #45 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    I know this is going to sound kinda stupid, but wouldn't it make more sense for this to be in the engine section under the l67/l32? That is the first place I looked when I was trying to find it.
  6. #46 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Jan 2012
    Philadelphia
    Should be stickyed somewhere
  7. #47 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    It is stickied, just in the How to section. And when I was trying to find it I was looking in the engine section.
    Sent from A Galaxy Far Far Away........
  8. #48 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Dec 2012
    troll land
    X2 on these questions
    Quote Originally Posted by johntremell View Post
  9. #49 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Mercer, Pa
    Re-read the thread, you need a adapter plate to bolt the N* throttle-body up or any throttle-body. You need a tune to make it work, you need electrical adapter to plug it in and need bracket adapter to hook up throttle cable and cruise control.
    Porting the manifold does not gave any significant performance increases. Flow restrictions are in the heads once you switch to a gen 5 supercharger.
  10. #50 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    SE Level Member BlackGTP01's Avatar
    Nov 2014
    Reno
    I just purchased a rebuilt Gen V directly from Eaton
    Great write up, already printed this out to help me through this swap!
    Another question I was curious about, after you get this done are you supposed to remap your PCM? I'm hoping to stay running my 3.25 pulley on the new S/C so I'm a little nervous about the KR.
    Thanks for any advice
  11. #51 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Nov 2011
    NY
    Quote Originally Posted by BlackGTP01 View Post
    what year, model, mods? Why nervous? You have read the Safely Modding your GP thread right? Lol...
  12. #52 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Kemmerer, Wyoming
    a 3.25 pulley on a gen 5 is roughly the equivalent of a 3.0 on a gen 3 so you are probably going to need a full size intercooler with rockers or a cam, definitely need headers, and larger injectors.
    Getting a re tune after a modification like this is likely going to make a big difference, but the car should run fine without it, barring any kr because you may not have the required supporting mods.
  13. #53 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Nov 2014
    Reno
    2001 Grand Prix GTP, Intake, Headers, Magnaflows, smaller pulley with tune.
    To be honest I'm not 100% what size the pulley is, I purchased the car with these mods and the previous owner bought it from a dealership as a trade in the way it is now also.
    I'll have to look into it. (Duh)
    I'm just going to be into this Gen V swap for a decent amount of money when I purchased the car a month ago. Very frustrating.
    It was my daily so I don't plan on modding it any further so I'll make sure to stick to a 3.4 it sounds like.
    I just want the thing to run! haha
    Thanks for the advice.
  14. #54 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Kemmerer, Wyoming
    a 3.4 is still too aggressive for a gen 5 with those mods, you would probably be lucky to have no kr with a 3.6 on a gen v and those mods. there really is almost no benefit to running a gen v unless you are building a monster build. if you can return the supercharger for a refund you would probably get as much benefit from a ported gen 3, and have less money into it.
    http://www.regalgs.org/topic/54470-g...l=supercharger
  15. #55 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Nov 2014
    Reno
    The S/C rotor locked up. I didn't want to spend 400 to go back to exactly what I had. I saw all this talk about the Gen V swap and it's around the same cost.
    But there's a lot more to it then "bolt on" like everyone says. But it's too late now to turn around. I already have almost everything to do it.
    I'll have to get a 3.6 on order just incase. Thanks for the input
  16. #56 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Kemmerer, Wyoming
    seems like an expensive fix just for a locked up rotor pack
  17. #57 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Mercer, Pa
    Sounds like a great fix, old one is bad new one is upgrade. Most people upgrade a working supercharger.
  18. #58 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    GT Level Member glendayle's Avatar
    Salt Lake City
    Hhh
    1999 Regal GS Mods-180 tstat; CAI FWI; ubend delete/3"DPCB PLOG; HID fog conversion, 3.5, tint(42%/20%), TK Trans 3.29 gears
  19. #59 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Nov 2014
    Reno
    So I've read this a couple times and I still can't seem to figure out the answer. I purchased the adapter plate for my TB to bolt up to the Gen V, which it already has the fitting installed on it. I ran a line from the fitting back to the nipple on the back on the S/C.
    My question is about the inlet next to the nipple, I can't seem to figure out how to fix this issue.
    I'm sure the answer is here I'm having a hard time figuring it out.
    It's Picture 12, the inlet right next to where you mount the TB.
    Thanks for any input!
  20. #60 Re: The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    Mercer, Pa
    The 12 th picture shows a port to the right of TB. Surface This gets capped or blocked. There was a valve in there for gas tank purge system. Your gen 3 car has a similar looking valve but it is not attached directly to supercharger.
  1. Replies: 716
    Last Post: 01-06-2018, 05:44 PM
  2. Eaton M90 Gen V supercharger problems
    By 05GTPcmpg in forum Off Topic Discussion
    Last Post: 06-04-2011, 11:20 PM
  3. Need pcv help for IC'd GenV swap
    By 00gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 04:44 PM
  4. Can I install eaton m62 supercharger on L36 engine?
    By SBB in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2010, 01:15 PM
