Thread: How to pull an engine: BillBoost Style
Page 6 of 6 FirstFirst ... 456
Results 101 to 105 of 105
  1. #101 Re: How to pull an engine: BillBoost Style
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    After all these years of working on GP's , this is still a well written article
  2. #102 Re: How to pull an engine: BillBoost Style
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Couple questions...
    Can anyone get this link to work? I change to .com and brings me back to the home page 404 Not Found
    Is there any reason a 1 ton engine hoist wouldn't do the job? It's the cheapest one I can find used in the area. Will only be using once so don't want to by anything new.
    I think i've got all the information I need saved in a word doc that i'll print for when I'm ready to tackle this. Just trying to make sure I have everything thought out and don't need to stop in the middle for any reason.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  3. #103 Re: How to pull an engine: BillBoost Style
    one ton hoist is fine. you need the photo bucket extension from the chrome store to see the pics. not that theres all that many.
  4. Thanks SomeDudeAtHome thanked for this post
  5. #104 Re: How to pull an engine: BillBoost Style
    Engine alone is probably around 600lbs. When lifting engine with trans, a one ton might get a little light in the back end. But you should be fine.
  6. Thanks SomeDudeAtHome thanked for this post
  7. #105 Re: How to pull an engine: BillBoost Style
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Using these instructions now. Thanks again BillBoost!
  1. Test BillBoost
    By BillBoost37 in forum Off Topic Discussion
    Last Post: 07-26-2011, 12:38 PM
  2. Thanks to Bio, Billboost, 01GTP, Reptile, Blue and others
    By Silver GTP in forum Shops and Community Heroes
    Last Post: 09-09-2010, 10:11 AM
  3. New headers after engine pull lots of noise
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 11:37 PM
  4. Engine and Trans pull... SAME TIME?
    By nathangartz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 09:40 PM
  5. pull engine?????
    By kingd44 in forum Off Topic Discussion
    Last Post: 08-10-2008, 09:12 PM
