Thread: How to pull an engine: BillBoost Style
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 105
  1. #81 Re: How to pull an engine: BillBoost Style
    SE Level Member Stoenr's Avatar
    Aug 2015
    Chicago Burbs
    Great wright up! And thanks to seventone for adding his pictures. Have went over this thread and others a few times prior to pulling my sons motor(only) out to seal up some leaks, but mainly replace a damaged flex plate.
    Everything going pretty smooth for a father and son whos never yanked a motor all the way out.
    My question is, he has headers on his car, and looking like the rear ones will have to be unbolted from the motor. Now they were off not to long ago so not worried about breaking anything etc, but just verifying if you agree, they will need to come off? The front looks ok on clearance, pretty close to fan shroud tho, assuming the engine removal goes pretty much wiggle wiggle and straight up and out.
    Ford Guy, Kids the GP guy.
  2. #82 Re: How to pull an engine: BillBoost Style
    Buffalo
    Every engine I removed , the headers went on after the engine was in the car.
    This leaves plenty of room and provides access to the rear trans bolts
  3. #83 Re: How to pull an engine: BillBoost Style
    Quincy, Mass
    You need to remove the front header, disconnect the rear header from the head and that can stay in the engine bay. Your not going to have a good time if you leave them attached.
    No more GP 04 Impala SS Indy:
  4. #84 Re: How to pull an engine: BillBoost Style
    Aug 2015
    Chicago Burbs
    Quote Originally Posted by Swiggles View Post
    It came out with disconnecting the crossover and rear. front stayed on.
  5. #85 Re: How to pull an engine: BillBoost Style
    Buffalo
    Exactly how I do it every time
  6. #86 Re: How to pull an engine: BillBoost Style
    i too unbolted the headers, not a big deal really.
    take the plugs out first so you dont break em. they are the last thing you install after it back in too.
  7. #87 Re: How to pull an engine: BillBoost Style
    Buffalo
    I recommend using header bolts not the stock studs.
  8. #88 Re: How to pull an engine: BillBoost Style
    Quote Originally Posted by CrazyGuy03 View Post
    if your buying new bolts, stop there and get studs, they work so much better. bolts really do suck for headers.
  9. #89 Re: How to pull an engine: BillBoost Style
    Buffalo
    Wait I'm confused. You prefer the ones that have a stud sticking out on top of the bolt head aka OEM bolts?
  10. #90 Re: How to pull an engine: BillBoost Style
    Buffalo
    These ones
    bonus fact - during my rebuild I misplaced these and had to reuse the OEM bolts and changing the plugs those posts get in the way
    then a week later I found my header bolts
  11. #91 Re: How to pull an engine: BillBoost Style
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    I would only go for bolts if they were stainless... Rust sucks.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  12. #92 Re: How to pull an engine: BillBoost Style
    ask any one, studs are stronger then bolts. and you feel them tighten up much more.
    studs do stick out, but for the clamping power, ill take it. this is a 6.0 1/2 the bolt heads snapped off on their own. stock crap i know, all the same tho, ill take studs.
  13. #93 Re: How to pull an engine: BillBoost Style
    Buffalo
    No kidding ... well shît
    maybe I won't bother swapping them then
  14. #94 Re: How to pull an engine: BillBoost Style
    same reason you use head studs, they just clamp better.
  15. #95 Re: How to pull an engine: BillBoost Style
    Buffalo
    Well to be fair to my own argument - I don't torque the piss outta the headers and anti-seize is on every bolt in my car that allows it
  16. #96 Re: How to pull an engine: BillBoost Style
    Nov 2011
    NY
    One word of advice is if you go ARP head bolts/studs, to check the fitment of the headers onto the heads prior to install. My pacesetters required some grinding to give room for the nuts on the studs which sit higher than the oem... Pics available if required, lol. After fitment you can and want to take them (headers) off for engine install.
  17. #97 Re: How to pull an engine: BillBoost Style
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    This method worked flawless for me this past spring. It took me about 24 hours of labor to pull engine/trans, rebuild engine, rebuild suspension and brakes, reinstall engine/trans and run some new wires for a top-swap. Did it over a 3 day weekend with air tools.
    I am in the minority but I dropped the engine/trans in with the front and rear header installed. Had to use the engine leveler and push the a/c line but it wasn't too bad. I think I had the radiator pulled too but can't remember if it was in or not at the time of install. Did a flush and clean. I remember it being a tight fit and going slow not to damage anything.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  18. #98 Re: How to pull an engine: BillBoost Style
    Quincy, Mass
    Tog headers you could leave on but it's much easier to do with out.
  19. #99 Re: How to pull an engine: BillBoost Style
    Jan 2013
    Chicago
    once again, a great help! Thanks Bill!
    BUILT. Not Bought.
    00 GTP Daytona. 111k and counting
  20. #100 Re: How to pull an engine: BillBoost Style
    Jan 2018
    US
    Thanks a million for this!!
    Sent from my SM-N950U using Tapatalk
  1. Test BillBoost
    By BillBoost37 in forum Off Topic Discussion
    Last Post: 07-26-2011, 12:38 PM
  2. Thanks to Bio, Billboost, 01GTP, Reptile, Blue and others
    By Silver GTP in forum Shops and Community Heroes
    Last Post: 09-09-2010, 10:11 AM
  3. New headers after engine pull lots of noise
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 11:37 PM
  4. Engine and Trans pull... SAME TIME?
    By nathangartz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 09:40 PM
  5. pull engine?????
    By kingd44 in forum Off Topic Discussion
    Last Post: 08-10-2008, 09:12 PM
