Thread: Engine Mount Replacement [*]
Results 1 to 20 of 43
Threaded View
Abrasive Engine Mount Replacement [*] 06-15-2008, 10:40 PM
Abrasive Re: Engine Mount Replacement 06-15-2008, 11:12 PM
Toofastgs Re: Engine Mount Replacement 06-15-2008, 11:45 PM
SyntheticShield Re: Engine Mount Replacement 06-15-2008, 11:47 PM
SyntheticShield Re: Engine Mount Replacement 06-15-2008, 11:46 PM
02BlueGT Re: Engine Mount Replacement 06-15-2008, 11:53 PM
Abrasive Re: Engine Mount Replacement 06-15-2008, 11:53 PM
SyntheticShield Re: Engine Mount Replacement 06-16-2008, 05:05 AM
UR LOSN Re: Engine Mount Replacement 06-16-2008, 12:49 AM
alacran Re: Engine Mount Replacement 06-16-2008, 01:42 PM
Abrasive Re: Engine Mount Replacement 06-16-2008, 10:14 PM
alacran Re: Engine Mount Replacement 10-14-2008, 06:48 PM
Abrasive Re: Engine Mount Replacement 10-17-2008, 10:54 PM
Iron Indian Re: Engine Mount Replacement 06-22-2008, 09:46 PM
Abrasive Re: Engine Mount Replacement 06-28-2008, 10:55 AM
Toasty Re: Engine Mount Replacement 06-23-2008, 01:11 AM
RichCresci Re: Engine Mount Replacement... 11-25-2008, 09:38 PM
popeyenate Re: Engine Mount Replacement... 01-11-2009, 11:31 AM
Abrasive Re: Engine Mount Replacement... 01-11-2009, 10:38 PM
GTPrix Re: Engine Mount Replacement... 01-15-2009, 07:54 PM
Abrasive Re: Engine Mount Replacement... 01-15-2009, 10:18 PM
GTPrix Re: Engine Mount Replacement... 01-17-2009, 09:32 PM
keenan00gtp Re: Engine Mount Replacement... 02-02-2009, 11:47 PM
Abrasive Re: Engine Mount Replacement... 02-03-2009, 07:17 PM
Sykkel Re: Engine Mount Replacement... 05-29-2009, 05:18 PM
Iron Indian Re: Engine Mount Replacement... 07-12-2009, 10:30 PM
brandonjnaz Re: Engine Mount Replacement... 06-01-2009, 01:52 PM
brandonjnaz Re: Engine Mount Replacement... 06-01-2009, 01:55 PM
alacran Re: Engine Mount Replacement... 06-23-2009, 11:17 AM
dnomaam1 Re: Engine Mount Replacement... 07-12-2009, 06:03 PM
silvermistchick Re: Engine Mount Replacement... 08-09-2009, 02:13 PM
brandonjnaz Re: Engine Mount Replacement... 08-27-2009, 07:56 PM
brandonjnaz Re: Engine Mount Replacement... 08-27-2009, 07:58 PM
GeeBee Re: Engine Mount Replacement... 03-19-2010, 01:56 PM
Chizzler Re: Engine Mount Replacement... 05-23-2010, 07:14 AM
Logan541 Re: Engine Mount Replacement... 01-29-2012, 06:09 PM
Scottydoggs Re: Engine Mount Replacement... 01-29-2012, 06:20 PM
Bio248 Re: Engine Mount Replacement... 01-30-2012, 01:52 PM
SlowNA06 Re: Engine Mount Replacement... 01-30-2012, 02:48 PM
BillBoost37 Re: Engine Mount Replacement... 01-30-2012, 09:18 AM
chuckb223 Re: Engine Mount Replacement... 03-04-2012, 01:42 PM
ShadowSwept Re: Engine Mount Replacement... 04-07-2012, 06:17 PM
Obnoxio Re: Engine Mount Replacement... 06-09-2013, 01:24 AM
  1. #31 Re: Engine Mount Replacement [*]
    SE Level Member GeeBee's Avatar
    Iowa
    Click picture to enlarge
    This is the motor mount on my 06 GP GT - As you can see the motor mount to motor bracket different and has much tighter clearances for the bolts to the motor mount red circles - I wasn't even able to get an end wrench in there.
    So when you reach the point on an 04+ where you're stumped follow these. I may have gotten carried away on the detail, and sorry for the lack of step by step pictures. But this is in addition to the existing how-to it is not a complete how-to.
    First Remove the locking nuts connecting the motor mount to the cradle.
    Note for removing the old mount i removed the bracket from the motor before releasing the motor mount from the cradle - this is very bad for the threads on the horizontal bolt connecting the bracket to the motor.
    Then Apply enough pressure to make the motor mount come free from the cradle.
    Then remove the nuts circled in yellow to drop the bracket off the motor.
    You now have clearance to remove the nuts from the top of the motor mount that connects the bracket, i did this after removing the motor mount from the car, which requires jacking the motor up for more clearance.
    Re-assembly with ZZP Poly Motor mount - The motor mount is bigger and caused a clearance issue with the rear bolt that mounts the bracket to the motor while the bracket is torqued down onto the motor mount.
    So In order to get the assembly back into the motor with a zzp poly motor mount(without taking a chunk out of it)
    Place the motor mount without the bracket into the cradle
    Then place the bracket over the studs for the motor mount and barely thread the nuts on.
    Loosely put the vertical bolts attaching the bracket to the motor in.
    Fully tighten the nuts to tighten the bracket to the motor mount - I had to get a 15mm Bent end wrench for clearance - my straight 15 would hit the boot and didnt have enough clearance to torque it.
    Mostly tighten the vertical bolts from the bracket to the motor
    Adjust jack height to align center hole put the center horizontal bolt into connect the bracket - I had mine on a floor jack and had to pull the floorjack to move the motor trans forward to get alignment.
    Fully torque down all the bracket bolts - i had to tighten the rear one with an open end wrench, a thin closed wrench may get onto it though.
    Lower the engine all the way
    Put the nuts onto the cradle / motor and torque them down.
    Last edited by GeeBee; 03-19-2010 at 03:33 PM. Reason: Tweaked end of procedure after actually doing it.
    2006 Grand Prix Gt - Wizair, Solid Poly Mounts
    1996 Olds 98 Regency Elite - Dieing of Car Cancer and old age.
  1. Spacing lower engine motor mount...
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2012, 03:51 PM
  2. Could it be an engine or tranny mount?
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2010, 11:12 PM
  3. Engine mount idea
    By Andrew_99GTP in forum General Tech Discussion
    Last Post: 06-04-2008, 09:56 AM
  4. Motor mount help for 94 GP
    By 954mula in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-07-2008, 12:02 AM
  5. Problems Starting after Engine Replacement.
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2008, 07:54 PM
