Thread: Engine Mount Replacement [*]
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Abrasive Engine Mount Replacement [*] 06-15-2008, 10:40 PM
Abrasive Re: Engine Mount Replacement 06-15-2008, 11:12 PM
Toofastgs Re: Engine Mount Replacement 06-15-2008, 11:45 PM
SyntheticShield Re: Engine Mount Replacement 06-15-2008, 11:47 PM
SyntheticShield Re: Engine Mount Replacement 06-15-2008, 11:46 PM
02BlueGT Re: Engine Mount Replacement 06-15-2008, 11:53 PM
Abrasive Re: Engine Mount Replacement 06-15-2008, 11:53 PM
SyntheticShield Re: Engine Mount Replacement 06-16-2008, 05:05 AM
UR LOSN Re: Engine Mount Replacement 06-16-2008, 12:49 AM
alacran Re: Engine Mount Replacement 06-16-2008, 01:42 PM
Abrasive Re: Engine Mount Replacement 06-16-2008, 10:14 PM
alacran Re: Engine Mount Replacement 10-14-2008, 06:48 PM
Abrasive Re: Engine Mount Replacement 10-17-2008, 10:54 PM
Iron Indian Re: Engine Mount Replacement 06-22-2008, 09:46 PM
Abrasive Re: Engine Mount Replacement 06-28-2008, 10:55 AM
Toasty Re: Engine Mount Replacement 06-23-2008, 01:11 AM
RichCresci Re: Engine Mount Replacement... 11-25-2008, 09:38 PM
popeyenate Re: Engine Mount Replacement... 01-11-2009, 11:31 AM
Abrasive Re: Engine Mount Replacement... 01-11-2009, 10:38 PM
GTPrix Re: Engine Mount Replacement... 01-15-2009, 07:54 PM
Abrasive Re: Engine Mount Replacement... 01-15-2009, 10:18 PM
GTPrix Re: Engine Mount Replacement... 01-17-2009, 09:32 PM
keenan00gtp Re: Engine Mount Replacement... 02-02-2009, 11:47 PM
Abrasive Re: Engine Mount Replacement... 02-03-2009, 07:17 PM
Sykkel Re: Engine Mount Replacement... 05-29-2009, 05:18 PM
Iron Indian Re: Engine Mount Replacement... 07-12-2009, 10:30 PM
brandonjnaz Re: Engine Mount Replacement... 06-01-2009, 01:52 PM
brandonjnaz Re: Engine Mount Replacement... 06-01-2009, 01:55 PM
alacran Re: Engine Mount Replacement... 06-23-2009, 11:17 AM
dnomaam1 Re: Engine Mount Replacement... 07-12-2009, 06:03 PM
silvermistchick Re: Engine Mount Replacement... 08-09-2009, 02:13 PM
brandonjnaz Re: Engine Mount Replacement... 08-27-2009, 07:56 PM
brandonjnaz Re: Engine Mount Replacement... 08-27-2009, 07:58 PM
GeeBee Re: Engine Mount Replacement... 03-19-2010, 01:56 PM
Chizzler Re: Engine Mount Replacement... 05-23-2010, 07:14 AM
Logan541 Re: Engine Mount Replacement... 01-29-2012, 06:09 PM
Scottydoggs Re: Engine Mount Replacement... 01-29-2012, 06:20 PM
Bio248 Re: Engine Mount Replacement... 01-30-2012, 01:52 PM
SlowNA06 Re: Engine Mount Replacement... 01-30-2012, 02:48 PM
BillBoost37 Re: Engine Mount Replacement... 01-30-2012, 09:18 AM
chuckb223 Re: Engine Mount Replacement... 03-04-2012, 01:42 PM
ShadowSwept Re: Engine Mount Replacement... 04-07-2012, 06:17 PM
Obnoxio Re: Engine Mount Replacement... 06-09-2013, 01:24 AM
  1. #1 Engine Mount Replacement [*]
    Odessa, MO
    This writeup on Engine Motor Mount Replacement has been added to the How To section and can be found HERE.
  2. #2 Re: Engine Mount Replacement
    Odessa, MO
    BTW, before anyone says anything, I did fix my supercharger belt while I was in here. I got the cover off and noticed it was one rib off on the balancer pulley, you can see the one rib on the outside of the pulley in these pics. Probably been that way since my coolant elbow fiasco (which is still on the to do list to fix). Luckily, it didn't damage the belt or worse, shred it on the Power Tour.
  3. #3 Re: Engine Mount Replacement
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    I see one thing wrong with this picture
    F**ckin Rebuild Another Motor. (FRAM)
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #4 Re: Engine Mount Replacement
    Oklahoma
    Quote Originally Posted by Toofastgs View Post
    I wasnt going to pick on him because of that, LOL
  5. #5 Re: Engine Mount Replacement
    Oklahoma
    VERY VERY nice write up. Should most definitely be put in the How To section. Thanks for taking the time to write this up. 5 star vote and rep points for you my friend.
  6. #6 Re: Engine Mount Replacement
    GTX Level Member 02BlueGT's Avatar
    Hoffman/Schaumburg, IL
    Good write-up, I may do this when I have my heads off for the top swap(motor will be much much lighter)....
    Oh and + rep for you
    2002 GT...CAI, Headers, Special Eddition two-tone leather interior added, HUD added, 12" Brake Upgrade, ZZP strut tower bars, gmpp sway bars, poly motor mounts, -6an braided SS fuel hoses , Hptuned, Headers, Top Swaped, 50lb inj, E85, 3.4
    I've got Boost!! Top swap Quesions? Click Here
  7. #7 Re: Engine Mount Replacement
    Odessa, MO
    Yeah Yeah... filter is getting swapped on the next oil change. If it makes it long enough. LOL!
    Give me a recommendation that I don't have to go out of my way to find.
  8. #8 Re: Engine Mount Replacement
    Oklahoma
    Quote Originally Posted by Abrasive View Post
    Purolator Pure One Premium filters seem to do well in testing. Mobil 1 EP filters arent horrible.
  9. #9 Re: Engine Mount Replacement
    I live here. UR LOSN's Avatar
    Rockford, IL
    Well done indeed!!!!
  10. #10 Re: Engine Mount Replacement
    SE Level Member alacran's Avatar
    Apr 2008
    Chicago, IL
    how did you know the engine mount was bad or was it?
  11. #11 Re: Engine Mount Replacement
    Odessa, MO
    Quote Originally Posted by alacran View Post
    I was leaking the hydraulic fluid out of it. I noticed it when investigating a popping noise in the right front.
  12. #12 Re: Engine Mount Replacement
    Apr 2008
    Chicago, IL
    do you have any pictures of the leak?
  13. #13 Re: Engine Mount Replacement
    Odessa, MO
    Not really, just this one in the write up. Fluid all over one end of it that I assume was from the mount since it was smashed flat.
  14. #14 Re: Engine Mount Replacement
    Moore, Oklahoma
    Got pics of how your dogbones are aligned? Noticed any difference? My Napa mount was a hair shorter than the stocker apparently because my passenger side is a little lower than the other side making my dog bones slightly crooked. I spaced out the motor mount a little, it still ain't right though IMO.
    I've been thinking about just paying the $$$ and getting OEM GM lower motor mounts (I should of done this in the first place!).
    Shawn W. Larsen
  15. #15 Re: Engine Mount Replacement
    Odessa, MO
    Quote Originally Posted by Iron Indian View Post
    Mine came out straight, they slid right in when I was finished. I can get a pic if needed. Did you replace the trans mount too? I haven't done it yet on mine yet. I haven't even looked at it, but if it is bad too and a new one raises that side, I can see where I might get what you're talking about.
  16. #16 Re: Engine Mount Replacement
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    to add another tip for getting the studs seated in the holes top and bottom-- when i changed mine, i ended up starting the nuts on the top threads, in an unequal rate, so as to change the position of the bottom two studs. (needed to angle them a bit to get them to line up)
  17. #17 Re: Engine Mount Replacement [*]
    SE Level Member RichCresci's Avatar
    Jul 2008
    with a smashed mount, would this cause headers to hit something while reversing heavily? because when i reverse something hit something and make a god awful sound.
  18. #18 Re: Engine Mount Replacement [*]
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    yeah, mobil1 filters and purolators come from the same place right? champion industries or somehting. i always thought fram was the best....until i found good sites saying otherwise...this is one of them...i switched to mobil 1 ep filter as stated above and found idle improved cold and hot...put an ep on my chysler van and the knocking sound it made with stock mopar filter (also a FRAM...GONE!!!) is not to be heard...its worth the extra 5 bucks every 3 months or so...get a better filter!!!
  19. #19 Re: Engine Mount Replacement [*]
    Odessa, MO
    Good news, that was the one and only FRAM filter ever on the car. Been using AC Delco ever since.
  20. #20 Re: Engine Mount Replacement [*]
    Wow - thanks. I might attempt this later this winter. I should crawl under and see if I am leaking hydraulic fluid out.
    Dumb question: is there one of these mounts on each side, or is it just a tranny mount on the other side?
  1. Spacing lower engine motor mount...
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2012, 03:51 PM
  2. Could it be an engine or tranny mount?
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2010, 11:12 PM
  3. Engine mount idea
    By Andrew_99GTP in forum General Tech Discussion
    Last Post: 06-04-2008, 09:56 AM
  4. Motor mount help for 94 GP
    By 954mula in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-07-2008, 12:02 AM
  5. Problems Starting after Engine Replacement.
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2008, 07:54 PM
