If the seal rips or the metal ring thingy comes off, replace the seal, they normally don't get damaged.
I didn't replace them on mine. And hardly any fluid comes out. If you jack the car up to that whatever side you are doing is higher than the other, it will slow the leak or prevent it.
That's true only reason I replaced mine while doing the shaft was cause it was leaking tranny fluid
Sent from my pager using Morse code. ... .. ... ....
