Thread: Adding a heated seat
Results 1 to 20 of 28
  1. #1 Adding a heated seat
    Never Never Land
    This weekend I decided to see if a heated seat would work in my car. The junkyard had a nice seat they said I could have for $25 I was eager to give this a try since i couldn't find a thread on here about it and i had no clue if it would work. My car is a 97, donor car is a 99. I'm not sure which years this will work on. Sorry no pics
    Things needed:
    Heated seat obviously (This one had power lumbar also)
    The switch and little cover plate
    Console harness out of the car with the heated seat
    A rather large torx bit (T50) and a 3/8 ratchet.
    First thing to do is pop up the center console. The shifter will need to be in N or D. Take it completely off so you have more room. Make sure your parking brake is engaged so your car doesn't start rolling.
    Pop off the connector on the left side of the conosle and then disconnect all the other connections. They include the 12v adapter, shifter light and a few others. Don't break the connector because you need them!
    Next is to slide the seat far enough forward to get to the bolts that hold the seat in. There is one on each side of the track. Then disconnect the harness under the seat and rock it forward to get the "hooks" out of the floorpan and take the seat out making sure not to scratch up your center console or anything else.
    After you've got everything of your donor car...or if you bought everything seperate do the same procedure to the car the seat is going into.
    After your seat and console harness is out put the new one in and do everything in reverse order.
    Finally enjoy your warm butt!!
    I would assume this would work with the passenger side seat if you can manage to find a passenger heated seat. You would need the harness out of that car also since the console harnesses are only wired for the options you have. EX if you don't have heated seats like me there won't be any wiring for them at all in the conosle..same applies for passenger heated seat..if the car didn't come with it then it wont have a connector in the console for it...but it more than likely is in the main harness like mine was.
  2. #2 Re: Adding a heated seat
    Cool!
    If your parking brake doesnt work you can keep your foot on the brake as well.
  3. #3 Re: Adding a heated seat
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    Did you actually do this? If so, how did you hook up your wires to the fuse box? When the connectors aren't there, the fuse box isn't hooked up properly. As far as I know, heated seats have their own fuse.
  4. #4 Re: Adding a heated seat
    Never Never Land
    Yes, I did this with my GP. It was very easy.
    Yes, your right the heated seat does have its own fuse...it should be labeled "HSEAT/LUM" meaning heated seat/lumbar. If you have this fuse in your fuse block your car should have the wiring for your heated seat.
    Look under your seat on the connector. There should be 2 orange, 2 black, a pink and a blue wire on the car harness...not the seat harness...theres a freakin ton of wires on the seat harness...at least on mine there is. Anyway if you have those wires i listed on the car harness you should be good to go.
    Honestly I think every car is setup with the wiring in there because it's part of the main harness...the harness with the switch in it is a pigtail that comes off of the main harness.
    Just check it out on your car, theres no way for me to know if its on your car lol.
  5. #5 Re: Adding a heated seat
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    Ive read about this quite abit accually. there was also a case were they used a driver side in a pass side since there is no heated pass seat. hard part is moving the controls over to the other side and that didnt seam hard
    silver 2003 Grand Prix GT List is on it's way to be updated
  6. #6 Re: Adding a heated seat
    GTP Level Member KwazrollinZ28GTP's Avatar
    FLINT/michigan
    i did this in my OLD GTP, and before i sold it i kept my GTX interior and put it in my new GTP for a year now i have had no heat because its not working, i know in fact the seat works, and the switch, but when i put it in my new GTP and inserted the fuse i can select high or low but theres no heat in the seat, and leather is by far VERY cold in the winter.
    1997 GTP 2DR RaceKAR
    1994 Z28 intake, small cam, exhaust leak
    2000 silverado 5.3l Z71 3.73gear posi, 3.5" lift 33" tires DIABLO Tune
  7. #7 Re: Adding a heated seat
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    Quote Originally Posted by KwazrollinZ28GTP View Post
    LOL thats why my GTP gets stored in the winter and my Blazer has cloth
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  8. #8 Re: Adding a heated seat
    Banned
    Mansfield, Ohio
    Can any point me in the right direction to figuring out why my heated drivers seat isn't working properly. I was driving last winter, all of the sudden I knew something wasn't right. My azz was literally burning. I shut the switch from hi to the middle...off! Put it on low, no change burning me bad enough I had to keep my rear off the seat. Got out yanked the fuse and forgot about it until I saw this. It was crazy literally 130-140 degrees!
  9. #9 Re: Adding a heated seat
    Akron Ohio
    Damn.. Take that lol, I would think there is some sort of resistor that might of gone bad or a relay.
  10. #10 Re: Adding a heated seat
    Banned
    Mansfield, Ohio
    Ya I sure wish I knew what it was because it's cold as a mofo in Ohio, presently 12 degrees! I thought it was a bad switch but if that was the case it wouldn't get power at all. I just don't know what the heck the deal is!
  11. #11 Re: Adding a heated seat
    What do you need to know.
    Our heated seats are controlled via the switch. In the switch is two resistors one for high and one for low.
    In the seat bottom is a thermister than tells the relay when to turn on and off. (I'd say this is your issue, maybe a wire came unhooked in the heater, like the typical issue where they don't work.)
    The most common failure in our seats is the connection point where the wires going into the seat bottom connect to the heating element wire. The heating element wire is very thin and can be hurt easily. Reconnecting the wire is typically the free fix to having a heated seat again.
  12. #12 Re: Adding a heated seat
    Brought over a write up I've had on other forums etc.
    http://www.grandprixforums.net/how-f...tml#post467449
    If you guys would like a true how to add heated seats, I've got that as well.
    Added them to my 97 Bonneville and 00 Regal, as well as a few other cars etc.
  13. #13 Re: Adding a heated seat
    Grand Rapids, MI
    i would like to see the true how to add heated seats. my car came with no heated seats and cold leather + my butt = me unhappy right now.
  14. #14 Re: Adding a heated seat
    Yes and no.. I detailed how to make the harness...lol
  15. #15 Re: Adding a heated seat
    Nov 2008
    how did you get the texture to be right in the plastic after you sanded it?
  16. #16 Re: Adding a heated seat
    SEM makes the paints that match all car maker interiors so that you can repaint if needed etc. They also make a texture. A few test tries and you learn how close and how much to apply.
    Add in adhesion promoter and you'll have great success
    Texture
    Somewhere i have a pic of these two plus the correct paint for a few different things. The paint though is graphite.
    Now to go a bit off topic. Which do you want, homelink, fog light switch in duplicate or the original?
    Anyone recognize the fog light button? Once I put homelink where it originally was, I needed a different button.
    ABS defeat, EWP off switch, IC pump switch and PAC LED hole
  17. #17 Re: Adding a heated seat
    why is your bonne so awesomely equipped?
  18. #18 Re: Adding a heated seat
    Which part?
    Homelink
    Retaining steering wheel control
    Drag bags in the rear springs to keep traction
    Onboard air pump (factory) to pump up tires when leaving the track
    Window regulators that don't break
    AL7 seats (18 way) with heat added (never had it factory)
    Oil pressure gauge (factory)
    Boost gauge (needle, not a bar)
    Might have been because the motor had
    S1X
    1.8 Rockers
    Stage 3 heads
    Gen V
    WBS stage 3 IC
    Meziere EWP and 20gpm pump for IC
    Flow detect kit
    SLP's
    Funny part is the fat car got 2.5" piping from the factory. With rear drum brakes ...ack.
    FWIW, here's how I did a Regal.
    http://www.bonnevillepro.com/forums/...ng+for+a+regal
  19. #19 Re: Adding a heated seat
    Donating Users slopez's Avatar
    Dec 2010
    San Bruno
    2004 GT1
  20. #20 Re: Adding a heated seat
    factory equipment part...
  1. heated seat
    By ranchero in forum Introductions/Noob Questions
    Last Post: 01-03-2017, 07:35 PM
  2. heated seat
    By Ricky21 in forum General Tech Discussion
    Last Post: 04-23-2010, 10:43 PM
  3. 2000 GTP heated seat
    By vailskier3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2009, 12:01 AM
  4. Heated Seat
    By Rather B Blown in forum General Tech Discussion
    Last Post: 12-29-2008, 01:46 AM
  5. Heated seat not working
    By TJs97 in forum General Tech Discussion
    Last Post: 12-10-2008, 01:21 PM
