Thread: Adding a heated seat
Results 1 to 20 of 28
  1. #1 Re: Adding a heated seat
    Never Never Land
    Yes, I did this with my GP. It was very easy.
    Yes, your right the heated seat does have its own fuse...it should be labeled "HSEAT/LUM" meaning heated seat/lumbar. If you have this fuse in your fuse block your car should have the wiring for your heated seat.
    Look under your seat on the connector. There should be 2 orange, 2 black, a pink and a blue wire on the car harness...not the seat harness...theres a freakin ton of wires on the seat harness...at least on mine there is. Anyway if you have those wires i listed on the car harness you should be good to go.
    Honestly I think every car is setup with the wiring in there because it's part of the main harness...the harness with the switch in it is a pigtail that comes off of the main harness.
    Just check it out on your car, theres no way for me to know if its on your car lol.
  2. #2 Re: Adding a heated seat
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    Ive read about this quite abit accually. there was also a case were they used a driver side in a pass side since there is no heated pass seat. hard part is moving the controls over to the other side and that didnt seam hard
    silver 2003 Grand Prix GT List is on it's way to be updated
  1. heated seat
    By ranchero in forum Introductions/Noob Questions
    Last Post: 01-03-2017, 07:35 PM
  2. heated seat
    By Ricky21 in forum General Tech Discussion
    Last Post: 04-23-2010, 10:43 PM
  3. 2000 GTP heated seat
    By vailskier3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2009, 12:01 AM
  4. Heated Seat
    By Rather B Blown in forum General Tech Discussion
    Last Post: 12-29-2008, 01:46 AM
  5. Heated seat not working
    By TJs97 in forum General Tech Discussion
    Last Post: 12-10-2008, 01:21 PM
