Thread: How to remove a transmission
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 110
  1. #41 Re: How to remove a transmission
    Jun 2013
    Rhome
    How would you suggest putting the subframe back in?
  2. #42 Re: How to remove a transmission
    floor jack on each side, jack it up nice and slow and even, line it up, bolt it up. try to get the motor and trans mount in line on the way up.
    if they wont line up you can move the engine around to get the mount bolts to line up. after the frame is bolted up.
  3. #43 Re: How to remove a transmission
    Money vortex synysterjoe's Avatar
    Mar 2013
    Columbus
    Im surprised the cowl can take the weight of the engine like that.
  4. #44 Re: How to remove a transmission
    you and me both, that same 6x6 was holding my engine in the bay at bills house lol bill also used 2 2x4 pieces to clear the hood latch, the 2x4's went on both sides of the latch, then the 6x6 went on top of them. then chained the engine, pulled the mount bolts, then dropped the frame out.
  5. #45 Re: How to remove a transmission
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    Here goes nothing. About to start my trans Swap! Wish me luck!
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  6. #46 Re: How to remove a transmission
    Apr 2015
    Mesa AZ
    OK so im a total noob when it comes to replacing the trans... I hear that i do have to drop the sub frame and i have heard i dont have to which is it? Also do you have to drain the trans fluid? Im on a tight budget and i dont really have the money to replace the 11 or 12 quarts of trans fluid... thats another 50-65$ i dont want to spend if i dont have to... thanks for the great write up!
  7. #47 Re: How to remove a transmission
    Pick either way.
    Remover the motor and then remove the transmission, or lower the subframe and just remove the transmission out the bottom while supporting the motor from the top.
    And do you want to clean up 12 quarts of fluid off the ground or just a little spill from it seeping out from places??
    You'll want to drain the fluid and you'd need new fluid for the other transmission you are installing, you'd be foolish to not replace the fluid.
  8. #48 Re: How to remove a transmission
    Apr 2015
    Mesa AZ
    Ok cause I'm using the transmission out of a donor car and so I didn't know if I remove the fluid and put new stuff in if it would hurt it since I've had bad experiences with trans flushes ruining the transmission...
  9. #49 Re: How to remove a transmission
    drain the pan of the donor trans. its easy if its still in the donor car. or the fluid can leak out via the axle holes when you lift it up and in.
    same for your old tranny, drain the pan first, then take it out. you dont need to take the pan off, just crack the bolts free along two side to a corner, it will drain out that corner.
    pan drop is like 8 quarts, the donor tanny should be able to take it if its fluid looks good. i know you said low budget, but this is a great time for a shift kit to be installed. they run like 40 bucks or so. do put a new filter int he new tranny too. dont be to cheap. some stuff is just done because its dumb not to.
  10. #50 Re: How to remove a transmission
    Apr 2015
    Mesa AZ
    Ok sounds like a plan I will be draining the trans in both. How difficult is the shift kit?
  11. #51 Re: How to remove a transmission
    Mar 2014
    Tucson
  12. #52 Re: How to remove a transmission
    Apr 2015
    Mesa AZ
    Ok maybe I will look into getting it done but I just really wanna get this done
  13. #53 Re: How to remove a transmission
    Apr 2015
    Mesa AZ
    anyone in arizona that could come help? My one friend that was going to help is now out of town and i really want to get this done.
  14. #54 Re: How to remove a transmission
    Apr 2015
    Mesa AZ
    What trans fluid is best to get for our cars?
  15. #55 How to remove a transmission
    97-03 = Dexron III
    04+ = Dexron IV
    Brand doesn't matter
    04 Comp G.
  16. #56 Re: How to remove a transmission
    Apr 2015
    Mesa AZ
    Awesome thanks
  17. #57 Re: How to remove a transmission
    Apr 2015
    Mesa AZ
    So I'm in the middle of pulling the trans and can not for the life of me get the diff to engine bracket off the engine and I can not get the last blot on the back of the trans. Because of this please help
  18. #58 Re: How to remove a transmission
    There's 4 13mm bolts that originally hold the bracket. You should not loosen the engine to trans main bolts before doing this bracket as it'll possibly put pressure on the bolts.
    Which position bolt is fighting you?
  19. #59 Re: How to remove a transmission
    Apr 2015
    Mesa AZ
    I was having problems with the 2 engine bolts on the bracket I finally got them. Thanks for the reply tho
  20. #60 Re: How to remove a transmission
    Apr 2015
    Mesa AZ
    So i went to put the trans in today and i can NOT find the trans to engine bracket anywhere... is it a major issue if i dont have it for a few days till i can get one?
  1. How To Remove Transmission Help!
    By Hixc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-10-2014, 08:59 AM
  2. how to remove a 97 gp transmission?
    By 1997gp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2009, 12:10 AM
  3. how to remove a 97 gp transmission?
    By 1997gp in forum General Tech Discussion
    Last Post: 07-07-2009, 11:26 AM
  4. how do i remove the transmission
    By EMerola in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 12-09-2008, 07:28 PM
  5. How Can I Remove This ?
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 04-23-2008, 01:18 PM
