Thread: How to remove a transmission
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 110
  1. #81 Re: How to remove a transmission
    Jan 2018
    US
    Lol very true. Glad you told me that. I was going to try to see if I can get away with it. Thanks ha
    Sent from my SM-N950U using Tapatalk
  2. #82 Re: How to remove a transmission
    Support bars will do fine over a period of time, they are made to hold it up. I've had 4x4's holding up an engine in the bay for at least 2-3 weeks with no issues.
  3. #83 Re: How to remove a transmission
    Jan 2018
    US
    Changed it up. But I wanted to check with you guys first before I make it official.... Will these ratchet straps do the trick until next weekend, with no subframe? Decided not to use the chain etc that came with it
  4. #84 Re: How to remove a transmission
    that should work.
  5. Thanks showtastiik thanked for this post
    Likes showtastiik liked this post
  6. #85 Re: How to remove a transmission
    Jan 2018
    US
    By the way.... This write up worked like GOLD. Thanks! First time taking one out "CLEAN" as well. Now I'll have to put all these bolts back in place to put the new rebuild in[emoji20][emoji28] PS, wish I could read those markings on the torque converter...
  7. #86 Re: How to remove a transmission
    i had piles of bolts around both jack stands. had none left over. was a good day lol
  8. Likes showtastiik liked this post
  9. #87 Re: How to remove a transmission
    Jan 2018
    US
    Lol my goal is to have no bolts leftover like you haha
  10. #88 Re: How to remove a transmission
    If you have any questions when you get there.. just post pics of the bolts. There's enough people around here that did the job so many times.. it's easy to ID them.
  11. Thanks showtastiik thanked for this post
  12. #89 Re: How to remove a transmission
    Jan 2018
    US
    What's the best way to line up the engine mount. Trans mount is lined up and all 4 subframe bolts are in lightly
  13. #90 Re: How to remove a transmission
    need to wiggle the engine around some. they tend to pop in place with a little fiddling.
  14. Thanks showtastiik thanked for this post
  15. #91 Re: How to remove a transmission
    I don't usually tighten subframe until engine mount bolts are tight. but when doing just a mount.. I'll use a prybar to move engine around a bit. probably has to go back to slide in.
  16. #92 Re: How to remove a transmission
    Jan 2018
    US
    Seem's when I thought all will be well. Put 2 gallons on trans fluid in and its leaking from the driver side cv axle? Tell me the bad news? I'm sure no good news can come from this
  17. #93 Re: How to remove a transmission
    this a rebuilt tranny? or used? seal is bad, or the wrong one.
  18. #94 Re: How to remove a transmission
    Jan 2018
    US
    This the rebuild. Seal must be wrong or I put it in wrong one of the two. Back to the drawing board I guess
  19. #95 Re: How to remove a transmission
    theres a thread around here showcasing what seal works and what dont. one seal is like a mm to large.
  20. Likes showtastiik liked this post
  21. #96 Re: How to remove a transmission
    When you put the cover on, there's a seal that seals the cover to the .... the... the.. channel plate around the axle area. If this wasn't trans goo'd in and it turned, it'll leak. Pull the axle out of the driverside, undo the side cover bolts, redo that seal with more goo and put it back together. You won't be able to torque all the bolt, but you'll do enough and get a feel the the 18ft lbs (I think that's the spec) and can feel the others close enough. Flip axle back in and fill it up. Should be fine, I bet the seal rolled or something on you.
  22. Thanks showtastiik thanked for this post
  23. #97 Re: How to remove a transmission
    Jan 2018
    US
    This the seal you guys are talking about right?? I'll have to look for that thread to see what's what
  24. #98 Re: How to remove a transmission
    Negative
    You need to fix the seal that seals the outer side cover to the channel plate. It would be in a groove on the cover that seals where this red circle is drawn
  25. Likes showtastiik liked this post
  26. #99 Re: How to remove a transmission
    Jan 2018
    US
    And theres my problem haha thanks fellas.. No o ring
  27. #100 Re: How to remove a transmission
    now thats a whoopsie for sure lol
  28. Likes showtastiik liked this post
  1. How To Remove Transmission Help!
    By Hixc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-10-2014, 08:59 AM
  2. how to remove a 97 gp transmission?
    By 1997gp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2009, 12:10 AM
  3. how to remove a 97 gp transmission?
    By 1997gp in forum General Tech Discussion
    Last Post: 07-07-2009, 11:26 AM
  4. how do i remove the transmission
    By EMerola in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 12-09-2008, 07:28 PM
  5. How Can I Remove This ?
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 04-23-2008, 01:18 PM
