I did my fog light switch when I first got the car, its pretty straight forward. Sorry I don't exactly remember the part#s and such, I didn't think I was going to go apes**T with the swap. I know the stock is a 25 mini light. Seeing as mine has burned again I will be changing to a small led.
Now I can help as far as the color on the switches and any thing else that Pontiac decided to dip in red. Berryman's Chemtool Choke Cleaner and a cotton swab will pull the color right off. You want to use as small of a swab as you can so that you only take off what you want. My first one even took the grey out of it. After the Chemtool I used 1100 grit sand paper bound around a swab and lightly sanded untill I had what I wanted.
The results might look a little milky depending on how much paitence you put into it. I came back after all of this and used some 3M liquid polishing compound and the swabs and lightly buffed it and it looked good.
All you need from there is some translucent paint and blue masking tape.
I hope this helps some of you out.
As for the cluster I have an old cluster that I bought just for the needles, so I took the face off of it, I am going to cut a piece of the same blue plastic I used on the dic and make a backdrop for my glow gauges so that all of the warning lights are blue too.
