Thread: DIC COLOR CHANGE!!! First atempt, learn from my mistakes
Results 141 to 141 of 141
Threaded View
  1. #1 DIC COLOR CHANGE!!! First atempt, learn from my mistakes
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    okay so i saw this mod in another post and after asking around and not getting much if any response i decided to just tear into it and see what happened. and why not? i got nothing but time = outta work for 4-6 months from a bike wreck and massive shoulder surgery
    so first off take out and completely apart til it looks like this:
    then cut all these pins like this to flip the lcd open:
    (i didnt wanna desolder all those but its an option)
    then remove the backing of the lcd with a razor like this:
    then i used carb cleaner but paint thinner would be better to remove the red coloring from the piece
    next step i took a generic dvd case that was blue and cut a piece to put behind it like this:
    then just stuck them behind the lcd and resoldered the pins on the side really sloppily like this:
    then i went and bought my leds from two different radio shacks cause they didnt have enough at one store. i got 10mm blue leds for behind lcd and red leds for behind the buttons and some 560ohm 1/2 watt resistors like these:
    then drilled out the openings a bit with a 3/8"s bit and tucked them in like this:
    now when putting them in the polarity matters so i had to go plug it in and check and this is what i found out:
    keep in mind the longer of the two leads is the positive side...
    continued:
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  1. How to change the color of gauge needles??
    By colindunn in forum Visual/Body Modifications
    Last Post: 05-15-2010, 12:46 AM
  2. Newbie Mod Mistakes
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 02-26-2010, 04:40 PM
  3. I'm Here To Learn
    By meandnooneelse in forum Introductions/Noob Questions
    Last Post: 02-19-2010, 11:40 AM
  4. gauge cluster lights, anyone knows how to change the color
    By ricardo23 in forum Audio, Security & Visual Electronics
    Last Post: 09-01-2009, 08:36 PM
  5. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
