theres a diagram of the lights needed that Kejross drew at the top of page 4, i would refer to that
nice wright up.wish i could try this,but my soldering skills are not that good.
looks nice
Colussus..look at your link again..it says they are in stock...:lol:
Currently in the process going to radioshack soon today, I'll get back with some pictures when I'm done
Miniature Wedge Base Bulbs - Super Bright LEDs
I'm pretty sure the bulbs in the DIC are Sylvania #24, I could be wrong though. I just ordered a few of these bulbs will update when they arrive if they are a fit or not.
Hey everyone! So I have been reading this thread for months and trying to decide if I wanted to attempt this. I finally decided to do it, and I love the way it turned out. I have even gone as far as making my trac lights blue as well. I could use some opinions as I am trying to decide to leave all the buttons red or change them over to blue as well. I have never been a big fan of red but seeing the red and blue together Im kinda liking the scheme.
any help would be greatly appreciated.
http://i1065.photobucket.com/albums/...t/IMG_0051.jpghttp://i1065.photobucket.com/albums/...t/IMG_0050.jpg
I'd leave them be, unless you decide to do all of them blue (door lock/window switch, steering wheel controls, HVAC) I left mine red as well.
http://i1214.photobucket.com/albums/...3/DSC00021.jpg
Very good looking... I left mine red too, too hard to get rid of all the red in the car so it helps tie it together kinda. I am gonna do my foglight switch in blue here pretty soon though. I just picked up a spare last week to practice with and after taking it apart it looks really easy, maybe I'll do a write-up on that too.
i have done all my switches now, in the fogs i did white lighting and the same goes for were there was red it is either blue or white, also added a light in my mirror that shines down on cup holders kinda lke most pontiacs i know have
I did my fog light switch when I first got the car, its pretty straight forward. Sorry I don't exactly remember the part#s and such, I didn't think I was going to go apes**T with the swap. I know the stock is a 25 mini light. Seeing as mine has burned again I will be changing to a small led.
Now I can help as far as the color on the switches and any thing else that Pontiac decided to dip in red. Berryman's Chemtool Choke Cleaner and a cotton swab will pull the color right off. You want to use as small of a swab as you can so that you only take off what you want. My first one even took the grey out of it. After the Chemtool I used 1100 grit sand paper bound around a swab and lightly sanded untill I had what I wanted.
The results might look a little milky depending on how much paitence you put into it. I came back after all of this and used some 3M liquid polishing compound and the swabs and lightly buffed it and it looked good.
All you need from there is some translucent paint and blue masking tape.
I hope this helps some of you out.
As for the cluster I have an old cluster that I bought just for the needles, so I took the face off of it, I am going to cut a piece of the same blue plastic I used on the dic and make a backdrop for my glow gauges so that all of the warning lights are blue too.
just ask me and ill help you out, anything in particular or? but i will let you know most of my work was problem solving in the process but i think it all turned out great
That's me, problem solving in the process... I just hate tearing something outta my car not knowing exactly what parts I need to get it done and back in before I gotta go somewhere again. I'll probably just keep getting junkyard parts to work on then it's just a simple swap of the old part for the new modded one. Post some pics of it all though still, I wanna see what it looks like with them all done...
well thats how it goes, when i did my dimmer/ headlight switch i was told i would have to cut and it didnt come apart, well i looked at it and tried and peal back the front and sure as **** it was just like the hud dimmer. really easy, and i been at work since 3 ill take some shot in the dark garage for yall. anything in particular you wanna see first?
I didn't use resistors, straight blue leds dipped in paint like you suggested. Works great.
im planning on doing my DIC thanks to this write up but i was also wanting to do the rest of my switches and everything just maybe not all at once. Does anyone happen to know how many bulbs i would need for all the switches on the doors(its a 2 door btw),the lights around the DIC, and the lights behind my cluster? and any others i missed?
Been a while but there's a lens in there with red paint or tint or whatever and the carb cleaner disolves the red so you can wipe it off and make the lens colorless. Otherwise you would have purple if you were doing blue.
