Quote Originally Posted by gtp239 View Post
I changed mine to blue and they were working for like 5 min then the light shut off, any ideas? Is there some kind of fuse just for the back lights? The traction and button lights are still working. looked awesome while it lasted, im going to get new leds tomorrow see if i burned them out but i kind of doubt it cause i wired them in with the resisters. thanks
thats usually what happens when the resistor values are wrong... in your case too low. sure you used the same leds an 560ohm 1/2 watt? if you used a lower wattage 560 it may have burned up too. if your using the calculator max sure you use the regular values on the package and not the max values. let me know...
