Quote Originally Posted by gtp239 View Post
i used the 4 pin blue part#276-0023 and 560 ohm 1/2watt 5% tolerance resistors part #271-1116. when i put them in i had one of the resistors bypassed by some sloppy soldering but the other 2 were working so i took it apart again thats when i noticed the resistor bypassed so i re soldered everything and the same two worked for a few minutes then went off.
im deff going to try new leds tomorrow. when they were onn seemed kind of dim also if that has anything to do with it idont know. at least my soldering got way better from taking this thing apart and putting it back together so many times lol
sure you got the sides of the 4 pins lined up right? i dont know what else it could be... sounds like you did it all right.
