Thread: DIC COLOR CHANGE!!! First atempt, learn from my mistakes
Results 1 to 20 of 141
  1. #1 Re: DIC COLOR CHANGE!!! First atempt, learn from my mistakes
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    okay so i got bored tonight and decided to pop it out and see... looks way better and the 4 pin wasnt hard to solder in at all. you do need different resistors for the red led this time, the calc said i needed a 150 ohm 2 watt resistor which radio shack does not carry anything with that kinda wattage so you buy two 5 packs of the 680 1/2 watt resistors and just twist 4 together which equals out to about 165 ohms said my multimeter (ahh the powers of parallel wiring) and also using 4- 1/2 watt ones make 2 watts. the blue ones still used the 560 ohm 1/2 watt. my total cost for the parts i ended up using was under 20$ with tax(not counting the previous attempt of course)
    materials list as follows:
    3x- blue 4 pin led part#276-0023
    1x- 5 pack 560 ohm 1/2 watt resistors
    2x- red 4 pin led part#276-0020
    2x- 5 pack 680 ohm 1/2 watt resistors
    plus solder and a iron
    they do carry several other colors in this led im pretty sure they have green,yellow,pink as well but i dont know what resistors those would use
    not put back together but you can see the improvement:IMG_0508.jpg
    DIC COLOR CHANGE!!! First atempt, learn from my mistakes Attached Images
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  2. #2 Re: DIC COLOR CHANGE!!! First atempt, learn from my mistakes
    Feb 2010
    Oklahoma City, OK
    theres not much way to tell on these what the polarity is so i checked with my batt charger before i started soldering and this is what i came up with... dunno if you can make it out real well but the side with the most metal is neg like this:
    i took the neg side and folded it down to solder to board and left the posotive side up to atach resistor to
  3. #3 Re: DIC COLOR CHANGE!!! First atempt, learn from my mistakes
    brookfield connecicut
    looks nice
  1. How to change the color of gauge needles??
    By colindunn in forum Visual/Body Modifications
    Last Post: 05-15-2010, 12:46 AM
  2. Newbie Mod Mistakes
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 02-26-2010, 04:40 PM
  3. I'm Here To Learn
    By meandnooneelse in forum Introductions/Noob Questions
    Last Post: 02-19-2010, 11:40 AM
  4. gauge cluster lights, anyone knows how to change the color
    By ricardo23 in forum Audio, Security & Visual Electronics
    Last Post: 09-01-2009, 08:36 PM
  5. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
