Quote Originally Posted by Poil336 View Post
those are still using the 560 ohm resistors right? i got a couple of the two pin led's to work and you're right, they're really dim. at least now i know i'm wiring it right, i probably just burnt out the led that i was using. did you solder the resistor to both the negative pins or just one?
you wire the resistor in series to either the pos or neg side not both and sinve you got different leds i would go use the calc i posted a link to and put in your figures as they are probably different, might be why its so dim too, you may need less resistance.
