Thread: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 85
  1. #61
    Actually..... Theyll weep engine oil.
  2. #62 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Aug 2012
    Cedar Rapids, Iowa
    yeah I figured if anything it would leak oil from the lifter galley.. guess I might as well wait and see no need to get in a huge hurry if they end up not leaking at all
  3. #63 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    those bolts are in the head, not the lifter valley. (coolant flows through the heads, not oil) they will leak both over time. my end lim bolt by the egr, leaks coolant, it looks like its crying when the cars hot. no oil just coolant. the other bolts will leak out a black thin watered down mess into the bolt valleys. like you see in that video.
    if you failed to clean the old bolts of their old sealant you may be ok.
    Ever have the heads off and look at what theyre in? Theyre in the crankcase vacuum space. In other words they are in the same cavity as the rockers.
    Only thing most are in is oil.
  5. #65 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Guys, great video and write ups. I'm going to dive in and attempt this repair on a 98 NA 3.8. Question: Why did you replace the lifters in the video? Were they worn? Does this fall into the category of "while your're in there"? At 153K miles, what else should I replace while I have the motor open? Water pump maybe?
  6. #66 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Pennsylvania
    At 153k, I'd do the
    pump + gasket,
    aluminum coolant elbows,
    thermostat + gasket,
    injector o-rings,
    If you're feeling spunky,
    timing chain,
    timing chain tensioner,
    timing cover gasket
  7. #67 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Dec 2008
    ****'s Creek
    Not a question of spunky, it's a question of $$$$....daughter is away at school so I'm driving as a "spare" ride to save the 10mpg the Suburban gets. It can stay in the garage for a week while I plod through the work, but I have to draw the line at how much I can spend. Seems like the vehicles are killing me with repairs this year .
  8. #68 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Pennsylvania
    If money's the issue, then replace parts as they break.
  9. #69 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Apr 2008
    Wow...great write up! I haven't done this type of engine work since I overhauled my '66 El Camino in the mid '70's so this was a perfect tutorial. I have a 2001 GP GT with @93k. LIM has been leaking for a while but I just got the nerve to fix it. The only hang up I had was removing the LIM once (I thought) the bolts were removed. After trying everything short of a C4 charge, I discovered that I missed two bolt inside the LIM. One was completely submerged in oil and the other was just difficult to see (I'm old...). Here's a pic in case another novice runs into the same issue. Thanks again and great site!
    2001 GT Coupe
  10. #70 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Feb 2013
    Shreveport
    I'm having an issue guys. I have the blower off and removed 12 intake bolts and the thing still wont come loose. Anyone have any ideas?
  11. #71 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    You are positive you took out 12 10mm(3/8") bolts? Triple check. If so.. that's all the bolts.
  12. #72 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Feb 2013
    Shreveport
    They were out, I had to give it a few good thumps with a rubber mallet. Came off after that.
    Thanks for the help man.
  13. #73 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Apr 2013
    US
    rubber vacuum tee's can be found in harness # 24508742
  14. #74 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    man that tutorila is so helpfull im about to be doing mine soon
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  15. #75 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Quote Originally Posted by epon View Post
    who in their right mind would pay 35 bucks for T?
    Click on image to zoom
    24508742 - HARNESS
    (0) Reviews: Write first review
    SKU: 24508742
    Availability: Ships in 1-2 business days
    Pricing: $35.78
    Qty:
    Add to CartAdd to Wishlist Item Inquiry Tell a Friend
  16. #76 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Quote Originally Posted by Travisgt2 View Post
    man that tutorila is so...
    Sounds like a mexican dish.
  17. #77 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Jan 2013
    leavenworth ks
    so my a and l are backwards
  18. #78 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Jan 2014
    Port Orchard, WA
    Looks like I will be trying to get parts by friday and start this on Monday or Tuesday. I am going to call ZZ Performance in the morning and hopefully get the parts. Anyone have any better recomendation for a parts place?
  19. #79 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Ocala, FL
    Quote Originally Posted by BillPendleton View Post
    For gaskets and such?
    Amazon.com
    Also price check rockauto.com
    One of the two will be cheapest.
  20. #80 Re: Video tutorial: Lower Intake Manifold Gasket + Lifters in 33 minutes [*]
    Jan 2014
    Port Orchard, WA
    Quote Originally Posted by codyAK View Post
    Amazon.com
    I ended up just getting everything from NAPA. It was one stop and easy. I will be doing this today. Fingers crossed lol.
  1. Upper Intake Manifold Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 01-06-2012, 10:34 AM
  2. Runs 5 minutes...Stalls...Changed everything
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2009, 02:47 PM
  3. Lower Control Arms
    By SyntheticShield in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2009, 12:55 PM
