Actually..... Theyll weep engine oil.
those bolts are in the head, not the lifter valley. (coolant flows through the heads, not oil) they will leak both over time. my end lim bolt by the egr, leaks coolant, it looks like its crying when the cars hot. no oil just coolant. the other bolts will leak out a black thin watered down mess into the bolt valleys. like you see in that video.
if you failed to clean the old bolts of their old sealant you may be ok.
Ever have the heads off and look at what theyre in? Theyre in the crankcase vacuum space. In other words they are in the same cavity as the rockers.
Only thing most are in is oil.
Guys, great video and write ups. I'm going to dive in and attempt this repair on a 98 NA 3.8. Question: Why did you replace the lifters in the video? Were they worn? Does this fall into the category of "while your're in there"? At 153K miles, what else should I replace while I have the motor open? Water pump maybe?
At 153k, I'd do the
pump + gasket,
aluminum coolant elbows,
thermostat + gasket,
injector o-rings,
If you're feeling spunky,
timing chain,
timing chain tensioner,
timing cover gasket
Not a question of spunky, it's a question of $$$$....daughter is away at school so I'm driving as a "spare" ride to save the 10mpg the Suburban gets. It can stay in the garage for a week while I plod through the work, but I have to draw the line at how much I can spend. Seems like the vehicles are killing me with repairs this year.
If money's the issue, then replace parts as they break.
Wow...great write up! I haven't done this type of engine work since I overhauled my '66 El Camino in the mid '70's so this was a perfect tutorial. I have a 2001 GP GT with @93k. LIM has been leaking for a while but I just got the nerve to fix it. The only hang up I had was removing the LIM once (I thought) the bolts were removed. After trying everything short of a C4 charge, I discovered that I missed two bolt inside the LIM. One was completely submerged in oil and the other was just difficult to see (I'm old...). Here's a pic in case another novice runs into the same issue. Thanks again and great site!
I'm having an issue guys. I have the blower off and removed 12 intake bolts and the thing still wont come loose. Anyone have any ideas?
You are positive you took out 12 10mm(3/8") bolts? Triple check. If so.. that's all the bolts.
They were out, I had to give it a few good thumps with a rubber mallet. Came off after that.
Thanks for the help man.
rubber vacuum tee's can be found in harness # 24508742
man that tutorila is so helpfull im about to be doing mine soon
who in their right mind would pay 35 bucks for T?
Click on image to zoom
24508742 - HARNESS
(0) Reviews: Write first review
SKU: 24508742
Availability: Ships in 1-2 business days
Pricing: $35.78
Qty:
Add to CartAdd to Wishlist Item Inquiry Tell a Friend
so my a and l are backwards![]()
Looks like I will be trying to get parts by friday and start this on Monday or Tuesday. I am going to call ZZ Performance in the morning and hopefully get the parts. Anyone have any better recomendation for a parts place?
