Thread: 04+ Rack and Pinion replacement [*]
Results 1 to 20 of 66
  1. #1 Re: 04+ Rack and Pinion replacement [*]
    Nov 2010
    Michigan
    Thanks Bill! I have done the complete steering system on my lifted GMC Sonoma ZR-2, so I feel a little weird being intimidated by the tight quarters that I have to work in for getting at this rack (and probably the power steering pump while I'm at it).
  2. #2 Re: 04+ Rack and Pinion replacement [*]
    When you lower the back of the cradle 2-3 inches, it won't seem so tight or cramped. BTW, if you are considering change the sway bar or the center bushings, it's a perfect time to get at the bolts for the center bushings.
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. Really Nice Rack!
    By FastKatt in forum Off Topic Discussion
    Last Post: 04-05-2008, 04:22 AM
  3. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  4. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
