Thread: Porting Your Supercharger
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 70
  1. #1 Porting Your Supercharger
    Donating Users kfish's Avatar
    Ohio
    I got bored and decided to port my blower myself. Took some pics along the way, figured I'd make up a how to on it.
    First remove your fuel rail. Pull your fuel pump fuse and start the car, this will relieve the fuel pressure. Next disconnect your fuel lines on top of the blower. Im top swapped, so i can release my disconnects with just my fingers. If you have a GTP, you may need special quick disconnects tools. Once the lines are disconnected, go ahead and pull the vacuum line off the fuel pressure regulator. Next, there are 5 10mm nuts that need to be removed from the fuel rail. One is on top of the blower, the other 4 are at each corner of the fuel rail. Unplug each injector, and pop the rail off.
    Now to get the blower off. Lets get the belt off first, you'll need a 15mm socket, just pop the socket on the tensioner and pull the belt off. Now, there is a spark plug wire seperator by the snout, youll need to release that and move it out of the way. Now you're gonna need your 10mm here as well. There is a stud on the throttle body end of the blower, which will need a deep socket for. The bolt that goes through right by the snout, is a tad longer than the rest. Keep that in mind. The rest are all the same length. When your taking all of the bolts at, try to go in a criss cross pattern to keep from warping the blower case. Double check everything, and make sure you got all the bolts out. Sometimes its easy to miss one. Now take your intake off of the throttle body, whether is stock, or open cone, or a FWI, take it off the throttle body. Alright! Now to pull the blower off. Grab it by the snout and pull up, it should pop loose, at the reat, grab the tb and lift up to pop it loose. Chances are your going to need a new gasket at this point. Once the supercharger is free on both ends, go ahead and lift it out. You'll have to lift up about 2" then slide it towards the passenger side and out from under the wire loom. Go set the blower on your bench, and pick up the yellow o rings that are on the drivers side of the lower intake and throw them away. Grab a "beverage", you've gotten your blower off.
    Now to disassemble the supercharger, dont worry. Its easy. Grab your 10mm again, and take off all the bolts along the snout. I was lucky, ant my snout and rotors all came out in one piece, so i didnt lose any oil. Take some paper towel, and stuff down into the blower where the needle bearings are to keep debris from getting in. Now flip your supercharger over and take a look at what your going to be porting.
    You will see a V on the underside of the blower. This is the outlet, and this is what you'll be porting. You want to make it bigger, and make the lower corners of it extend out. You'll notice what I'm talking about in the pictures. Grab your dremel, die grinder, ot what ever your going to be using, and take a deep breath. As for bits, i got 2 bits from Sears. They are Vermont American Rotary Files. I got one round one, and one cone shaped one the corners. Part numbers are 16672 for the round one, and 16678 for the cone. Power up your tool and get ready to grind.
    Start by grinding the tabs out at the bast of the triangle. Like so:
    Now, same thing for the other side. Once you have both tabs ground off, lets start opening up the triangle. Like so:
    Again, likewise on the other side. Once its done, go around the entire thing again, and smooth up any dimples or rough edges that are left. My camera died before i was able to get any more pictures of the finished product. But, once your done porting what you wanted. take a blow gun and THOROUGHLY blow all the shaving out of the case. I also sprayed some brake cleaner on a shop towel, and wiped the inside of the case and the rotors as well. Next put the snout and rotors back into the case, and bolt it all together. Replace the gasket back on the lower intake, and put in the new yellow o rings that came with the gasket, and drop the blower back on your car, connect all fuel lines and injector connections, and replace the fuel pump fuse back into the fuse box. Get in your car and prime the fuel system by turning the key to the on position several times, finally, crank the car over and let it start. Check for any fuel leaks. If everythings good to go enjoy your ported blower !
  2. #2 Re: Porting Your Supercharger
    Good job for your first stab at it...I'd say bring the bottom of the "V" down to the bridge though.
  3. #3 Re: Porting Your Supercharger
    GT Level Member undecided's Avatar
    taylors falls MN
    hey do you think you could show a pic of that? im bored and have two extra sc's so im thinking about doin this to one of them
  4. #4 Re: Porting Your Supercharger
    Quote Originally Posted by undecided View Post
    Here is a pic before I finished...but as you can see...keep bringing the "V" portion down evenly until you get to the bridge at the bottom. Make sense?
  5. #5 Re: Porting Your Supercharger
    Ohio
    Thanks man, ill keep that in mind. I didnt think it turned out bad at all for my first time porting anything.
  6. #6 Re: Porting Your Supercharger
    Wooster, Ohio
    now people have said both ways if this actually does anything or not without being intercooled, whats the truth on this because it wouldn't make since to port your s/c and it not help at all. It has to do something even if your not i/c, just wouldn't make any since not to, i understand it helps greatly with a full stack but whats the truth on this, anyone have any numbers to throw out?
  7. #7 Re: Porting Your Supercharger
    Quote Originally Posted by Pittman06 View Post
    It kills knock.
    What you do only when IC'd is remove the H bridge and port the LIM.
  8. #8 Re: Porting Your Supercharger
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    thats not 2 open? i heard u defeat the purpose of the s/c if u make the opening 2 big, u lose boost.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  9. #9 Re: Porting Your Supercharger
    Quote Originally Posted by a98gtp4u View Post
    Right...but you would have to make it some stupid HUGE hole to really lose any boost.
  10. #10 Re: Porting Your Supercharger
    Wooster, Ohio
    oohhhh ok, thanks
  11. #11 Re: Porting Your Supercharger
    No problem.
  12. #12 Re: Porting Your Supercharger
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    yep, some say its a waste, i did mine after i did the intake gaskets. i'm sure it helps alot, so, why not!
  13. #13 Re: Porting Your Supercharger
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    bringing this back from the dead... for a few quick questions:
    1) Is there a need to drain coolant prior to doing this because the coolant runs through the LIM and TB? If not, how much do you loose?
    2) What's the average time that it takes for the bits to chrew through the aluminum using a die grinder? (are we looking at minutes or hours?)
    3) Does the throttlebody gasket have to be replaced each time it's removed or the the TB gasket reusable on our cars? I haven't taken the throttle body off on these cars, only the supercharger and LIM...
    THANKS!!!
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  14. #14 Re: Porting Your Supercharger
    1) barely any coolant, dont worry about draining it.
    2) not sure on this one, i used a CNC lathe so it only took me 10 minutes
    3) the throttle body gasket MIGHT need to be replaced. if its new enough it might be okay, but otherwise its a non-reusable gasket.
  15. #15 Re: Porting Your Supercharger
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    How did you do it on a CNC lathe? i was going to do it on a full CNC machine, but a lathe sounds much easier
    Thanks
  16. #16 Re: Porting Your Supercharger
    Tyler, TX
    awesome, thanks Bio!
    I know that when I ported the intake on my camaro it took forever with my dremmel. I have access to much bigger tools now. I have other issues I need to nail down before I get to do this though.
  17. #17 Re: Porting Your Supercharger
    2) Depends what size the bit is. If its a little dremel it'll take you forever. If its a pneumatic die grinder then its possible to get it done in 2-3 hours.
    3) Just pick one up at the dealer. They're cheap and you'll most definitely need one if its never been off.
  18. #18 Re: Porting Your Supercharger
    SE Level Member timmysgtp's Avatar
    Jul 2010
    marrero louisiana
    will it hurt 2 take the h bar out if you planing on getting a I/c in the future?? Just wondering because I wanna port mine and if it won't hurt til I get my I/c then I just wanna do all the porting at once
  19. #19 Re: Porting Your Supercharger
    youll have to open up the lower intake at the same time or there will be an area that isnt exposed to the outlet of the blower.
  20. #20 Re: Porting Your Supercharger
    SE Level Member GTX98's Avatar
    Frankfort
    Might have to do this when I have some free time on my hands
  1. Porting Gen 5 M90
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2010, 02:38 AM
  2. porting supercharger specs please
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2009, 01:18 AM
  3. TB Porting ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 06-01-2009, 12:10 AM
  4. Porting the LIM and SC?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2009, 09:41 AM
  5. porting
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2008, 05:29 PM
