Thread: porting supercharger specs please
Results 1 to 20 of 21
  1. #1 porting supercharger specs please
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    gonna port my supercharger...anyone got specs for how far i can go. using my dremel here and done want to remove too much material.
  2. #2 Re: proting supercharger specs please
    Banned - Busted For Scamming
    Feb 2009
    Specs? Hmm... here is some pics though....
    For this pic, see the very right part of the outlet that looks like it has a hole... well that was a mess up, dont go past that first hole you will be fine.
    Second pic.... inlet. Start by machining out to 78mm... like so....
    Then blend...
    Finished outlet....
    Finally... powdercoated goodness....
  3. #3 Re: proting supercharger specs please
    Feb 2009
  4. #4 Re: proting supercharger specs please
    Apr 2009
    ERIE
    so..on the site you gave me he still has the large seperation between the the traingle and bypass area. u have yours entire outlest area flat. it this due to two different superchargers or are they the same and yours works better?
  5. #5 Re: porting supercharger specs please
    Feb 2009
    They are the same superchargers. You want to take out that bar so that you optimize surface area of your intercooler. Make it look like the one above with the exception of what i said i went too far on the far right. You will see what im talking about when you look at the stock one.
  6. #6 Re: porting supercharger specs please
    Apr 2009
    ERIE
    cant wait to get my supercharger back now so i can port it.
  7. #7 Re: porting supercharger specs please
    Feb 2009
    Where is it? lol
    Im working on one today. Just depends on your tools and skill as to how long it takes. A complete outlet like that was done in 20 minutes with a router. Dremel, not so much lol.
  8. #8 Re: porting supercharger specs please
    Wausau, WI
    Where is it? lol
    did you do the powdercoating yourself in the above pics(the red one) that looked great!! and it wouldn match my car........
  9. #9 Re: porting supercharger specs please
    dont take out the H-bar unless your LIM is opened up to match it, intercooler or not.
  10. #10 Re: porting supercharger specs please
    Feb 2008
    Don't forget to cut the gasket to match the larger openings, too...
  11. #11 Re: porting supercharger specs please
    Feb 2009
    Quote Originally Posted by DanGTP View Post
    Lol yes dont forget that. Yes, i do all the work in-house.
  12. #12 Re: porting supercharger specs please
    Apr 2009
    ERIE
    hell ill do this too then....anyone got pics of what i need to do to port my lim
  13. #13 Re: porting supercharger specs please
    Bastard Reptile's Avatar
    Kansas City, MO
    Look at the one on ZZP's site, and copy that.
  14. #14 Re: porting supercharger specs please
    Quote Originally Posted by Reptile View Post
    I second that.
    https://www.zzperformance.com/products_img/162_1.jpg
  15. #15 Re: porting supercharger specs please
    Dec 2008
    michigan
    here is my zzp chargrer
    Its all about the inlet! the outlet work dont do crap unless you got an IC.
  16. #16 Re: porting supercharger specs please
    Feb 2009
    Quote Originally Posted by explokid View Post
    Not entirely true. The outlet gains are alot especially when you take out the bolt bosses for the "V"
  17. #17 Re: porting supercharger specs please
    the outlet increases efficiency and decreases outlet temperatures...how can you say it doesnt do anything? you are one messed up dude.
  18. #18 Re: porting supercharger specs please
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    The purpose of porting: Items are ported so that the outlet of item A matches the inlet of item B. Lets say the outlet of the TB looks like O and the inlet of the blower looks like o. You want to open up the inlet of the blower so it looks like O. Any bigger or any smaller and your being inefficient. The moral of the story, you have to make the inlets and outlets match.
    Polishing: Polishing (and routing down the outlet of the blower) smooths the rough surface thus reducing turbulence. Turbulence in this case is when air hits a rough surface and switches direction going a different way then intended. Moral of the story, you have to rout down and polish the surface of the outlet just enough so its smooth.
    How to port the blower inlet: minichopper6hp detailed exactly how to port the inlet of the blower in the second post of this thread. Match the size of the TB then blend it down so the ridge is eliminated. How much do you take off of the ridge? Just enough so it is eliminated. By ridge i mean the bump you will make by machining the inlet to match.
    In addition to porting it you want to fill up the long oval like indent on the bottom of the inlet. You can see a great example of this in minichopper6hp post, Pictures 2 and 3.
    Outlet: Flatten down the surface until it is smothe. How much do you take off, enough until its smooth. No measurements are required. Flatten down the bumps on the bottom of the triangle so the material is the same thickness as what you just routed. Take out the H-Bar if you want to, it really isnt necessary untill you have an IC. Its self explanator, dont go deeper then the surface you just routed down or wider then the outlet allready is. Now rout the bottom triangle down so it looks like a complete triangle, not like a weird triangle with bumps on the bottom. If you know what a triangle looks like you can do it.
    If you want to go one step further you can rout the lip at the bottom of the triangle a LITTLE bit (its if this helps a ton or not). This is the part below the triangle that is raised up creating the seal between the blower and the LIM. Blend the bottom of the triangle to this area in a round manner not square. Take less then half of the material away (from the survacce facing toward the inlet side of the blower). Take too much, or from the top of the lip and your screwed. You can see the finished job in exploki's post.
    2006 Grand Prix GXP
  19. #19 Re: porting supercharger specs please
    SE Level Member buford1972's Avatar
    Apr 2009
    Peoria, Arizona
    What style router bit did you use to remove the outlet bar?
  20. #20 Re: porting supercharger specs please
    a big beefy one. to take out that much material its best to just use a lathe.
  1. Cam specs?
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2017, 09:18 PM
  2. Monsoon specs
    By marc49 in forum Audio, Security & Visual Electronics
    Last Post: 10-13-2009, 11:11 AM
  3. i need torque specs
    By MTXGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2008, 12:14 PM
  4. need torque specs for...
    Last Post: 04-17-2008, 12:16 AM
  5. Torque specs
    By kstanko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 12:47 PM
