Thread: Make A 4" Fenderwell Intake (FWI)[*]
Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 199
  1. #1 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Akron, Ohio
    Hey guys Nub here . . . picking up an 05 Comp G this weekend. Looking to do this mod as soon as I get home with the car. Where did you guys get the parts from? I know pvc should be easy to find but I'm curious where you got the elbows and roof flashings from. Any detail you 04 + guys could provide me as to sizes and filter choice would be much appreciated!!!
  2. #2 Re: Make A 4" Fenderwell Intake (FWI)[*]
    SE Level Member gpcustom's Avatar
    Indiana
    Quote Originally Posted by JD05CompGTP View Post
    Elbows you will normally find at the autoparts store (autozone, etc), the roof flashing will be hardware store ( lowes, etc).
    As for building it I have a 04 grand prix and all I did was use the 3" PVC and the spectra filter that was on a previous topic - I didnt need to cut the brace and it took me 15 minutes. For full instructions they have a how to process at the beginning and I learn the process of the FWI by just reading the thread from top to bottem.
    2004 Pontiac Grand Prix GT - 3800 Bored and Stroked
    Stage 1 wing - Custom Tuned PCM (PRJ)
    GXP Suspension (Full Swap) - Complete Custom Exhaust
  3. #3 Re: Make A 4" Fenderwell Intake (FWI)[*]
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    On my 04 i wanted to stay true and do an actual 4" fwi... to have a true 4" it takes a bit of time and finagaling... u can pick up either a 3 or 7" cone and as for elbows you WILL NOT find a flexible 4" elbow unless ordered off of the interent... i used 2 or 3 hard 4" 45 degree elbows and the roof flashing you can get from any hardware store... the hard part of a true 4" on an 04+ is the MAF... the way i did it was to use some sort of rubber extension and use it to attach the maf and intake manifold... then use a 3 to 4" rubber converter piece and run your 4" pvc off of that... makes a hell of a roar... good luck... might get picks up for thos interested in a true 04+ 4" fwi
  4. #4 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Alabama
    does a cai or fwi actual do any thing for acc. or speed? is it worth the time and money on a N/A 3800? and i read it gives bad gas milage? is that true? i really just want to know that if i did it would i be able to tell?
    thanks
  5. #5 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Quote Originally Posted by noom14921992 View Post
    thanks
    Throttle response is a little better. Can't comment on the mileage, I drive in the city and mostly short distances or get stuck in traffic so I don't get any if I try (19 mpg on a good week, 15 on a bad one) Still can get 28 on the highways though.
    You can hear the sucking sound of air when the throttle body opens up. Also you get a nice sucking sound when the car's cold. When it warms up it does go away though.
  6. #6 Re: Make A 4" Fenderwell Intake (FWI)[*]
    GT Level Member Joe m's Avatar
    mesa,az
    what size cone would i use for my 99 gtp?
  7. #7 Re: Make A 4" Fenderwell Intake (FWI)[*]
    mesa,az
    so 80$ later for all the parts im going to go build mine right now!
  8. #8 Re: Make A 4" Fenderwell Intake (FWI)[*]
    mesa,az
    ok so your directions are kinda ****ed... the 4" to 3" coupler doesnt fit my tb if thats where its supposed to go. the 3" side is to big. and yes its a stock tb on a gtp. also how the hell am i supposed to get the 4" pvc into the 4" cut in half elbow? they are both the same exact size and not wanting to stretch to fit in lol.
  9. #9 Re: Make A 4" Fenderwell Intake (FWI)[*]
    mesa,az
    the tb where the 3" side of the coupler goes is 3 1/2 inchs. thats just the screen the rest is about 3 3/4 inchs. how am i supposed to stretch a 3" that big?
  10. #10 Re: Make A 4" Fenderwell Intake (FWI)[*]
    mesa,az
    so as i found out. its impossible to get the 4" pvc into the 4" 90 elbo. so looks like im not doing a fwi and just gonna put the cone as close as i can to the fender..
  11. #11 Re: Make A 4" Fenderwell Intake (FWI)[*]
    SE Level Member wildman4910's Avatar
    Florida
    What are doing with the CPU? I meen air flow wise. It looks like you just left it sit were the old air box went? The CPU does need air flow over it to keep it cool, thats why its in the air box to start with.
  12. #12 Re: Make A 4" Fenderwell Intake (FWI)[*]
    mesa,az
    its just sitting there. it still gets enough air. cuz the box is out of the way so the air is still coming in from under the headlights. jus tnot going into a box
  13. #13 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Intake...maybe 3-5 horsepower...
    Tuning? More...but not that much on an N/A car.
  14. #14 Re: Make A 4" Fenderwell Intake (FWI)[*]
    mesa,az
    so i drove my car for the first time in the rain since i did my intake. and it seems i have a small hole in my fenderwell. the air cone wasnt really wet but where the pcm sits was kinda wet. will it be ok or should i try to close it up?
  15. #15 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Jul 2008
    Tampa, FL
    close it up if you can...you don't want water getting in there.
  16. #16 Re: Make A 4" Fenderwell Intake (FWI)[*]
    GTX Level Member real diehl's Avatar
    Salina, KS
    Can't seem to find the 4" 90* rubber bend. Can you use a 45* pvc bend instead?
    Or does anyone know where they sell the 4" rubber bends?
    signature removed for inappropriate content.
    -bio
  17. #17 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Topeka, KS
    Lowes or Home Depot & most people use the 45* over the 90*
  18. #18 Re: Make A 4" Fenderwell Intake (FWI)[*]
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    My Lowes and Home Depot don't have em in 4". I used a 75* when I put my 3" together and it worked really well (the 75*, not the 3")
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  19. #19 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Salina, KS
    I checked Lowes they didn't have them...
    I'm guessing you could just use a 45* pvc bend in place of the 90* that was cut in half?
    -bio
  20. #20 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Topeka, KS
    Quote Originally Posted by realdiehl View Post
    Possibly. Also if you can't find them at Lowes you're not looking hard enuff.
  1. Make a difference section
    By LowlyfeGTP in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 03:15 PM
