Not sure if there is anoother one or not. But the questions about ''Where is the fuel door located at?'' and ''How hard is it to change the fuel pump'' are growing it seems. Hopefully it will help those that don't knopw how or need a quick reminder.
Alright. We will be installing a racetronics pump. Since there are not a LOT of people installing aftermarket pumps we will go over everything that pertains to the stock pump installation. If anyone needs the cupple additional details and steps that is required please let me know.
Things you will need-
Fuel pump quick disconects (get the round plastic ones)
Snap ring pliers (flat head screw driver worked fine for me)
Pliers
Fuel pump
Plastic fuel pump hose
Lets talk about safty real quick. Disconnect the battery. No smoking or trying to see in the dark with lighters. It's not worth you're car's life...or you'rs.
First off we will be working through the back seat. It is the best way for those who have access through the back seat.
Unscrew the nut caps and pry up on the cover to reveal the top of the fuel pump assembly.
Next unplug the two connectors that go on the pump assembly.The top of everything will be covered with dust and dirt. As with anything that involves moving parts you want to make sure it is clean when you are working with it. Especially with the fuel system.
So were going to brush and blow everything off. Should look like this when you're done.
Next were going to remove the snap ring. A screw driver worked fine for me.
Snap ring removed.
This is where the quick disconects come in at. The tool is the grey thing and you push it into the fitting and it expands the clips that hold the hose onto the fitting.
Repeat for all three. The one in the middle is for the evap system. You simply push it together and it comes off. When you're done it should look like this.
STOP! You need to be cafefull when pulling the assembly out of the tank. There is a float and you need to use caution when removing it.
Start by pulling the assembly out of the tank and start watching for the float.
Here comes the float.
Done with the removal!!!
