Take the clip out by depressing the two ends with pliers.
Do the same for the one under it.
Remove the sending unit and float assembly.
Here you can see the two clips that are on opposite sides of each other on the outer casing. You need to depress them both and slide the inner part out.
then disconect the pump harness and pull the old pump out. Also take the old pump out of the rubber outer casing and install that on the new pump. If you can't get it off simply make a slit down the side to ease the removal process.
The new pump is on the right with the old rubber casing installed.
Install the new filter on the new pump.
Install the pump into the inner casing.Then install the inner casing into the outer casing (fuel bucket) and push down and make sure you hear a click. Double check to make sure both the clips have locked into place.
Install the new fuel pickup tube and make sure it does not have any kinks and is not hitting anything. Then plug in the harness back inot the fuel pump.
YOU ARE DONE. And it should look like this.
Clean and inspect everything again and re-install into the tank.Also make sure you fill the fuel bucket up (there is a check valve so it will not drain out) and also make sure the tank is filled with at least 10 gallons. Let the pump sit for about 10 minutes before trying to prime it with the key on.
Any questions feel free to ask!
