That was my initial thought, but the person I snagged this trick off pulls 4 engines a day on average and says he's never had an issue, so I figured I'd try it.
I suppose if you want to be kind about it, you could remove steering shaft and drop subframe and split them on the ground then lift.
In my particular case, I didn't care about the transmission or the flexplate as I've got one I'm going to use, but it looks fine to me!
