Thread: My Junkyard Engine/Transmission Removal Method
Results 1 to 20 of 28
  1. #1 Re: My Junkyard Engine/Transmission Removal Method
    I'm thinking more about the crank seal/rear engine seal. You know the seal that's a given to do if you pull an engine.
    I have done this method.. but it felt like I should question the pressure on it.
  2. #2 Re: My Junkyard Engine/Transmission Removal Method
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Definitely a good point as always Bill! Though, personally, I always change those seals anyhow because I do NOT want to mess with them down the road!
    As stated earlier to anyone using the "questionable" methods I list below the main one, USE AT YOUR OWN RISK!
  1. Engine Removal: Should I pull the engine or drop the sub frame?
    By acidcrashdburnd in forum General Tech Discussion
    Last Post: 03-13-2013, 03:29 PM
  2. paid a guy to put a junkyard engine in my GP...mistake
    By tquarter in forum The Rant Forum
    Last Post: 08-21-2011, 10:18 PM
  3. Junkyard Engine
    By Remnant King in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2011, 03:34 PM
  4. Transmission Removal help
    By jagman454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2010, 11:42 PM
  5. Transmission removal 06 Monte Carlo SS v8
    By supercatxr7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-01-2009, 09:08 PM
