Thread: ZZP Stage 1 Voltage booster install
Results 1 to 6 of 6
  1. #1 ZZP Stage 1 Voltage booster install
    Omaha, NE
    I made this write up in 2009 for a local forum. You're welcome.
    What it does: Raises the voltage of your factory alternator by .6 (or 1.2 for a stage 2), which results in:
    Brighter headlights
    More power from your factory stereo or aftermarket amps
    Increased voltage to your fuel pump
    Ensures the coil pack operates at it's full potential
    Better heated seat performance
    Improved rear defrost performance
    Cost: $17.99 + shipping from ZZPerformance.com
    Skill level required: 1/10 (You have to be able to find your alternator)
    Applications: 96-2004 compatible (Does not work with '05+ Grand Prixs', 97-98 Grand Am, 97 LeSabre or 96/97 Bonneville)
    Options: Stage 2 (Designed for race applications only)
    Step 1: Order online at ZZPerformance.com
    Step 2: Wait for shipping (Took me 4 days because of a blizzard the 3rd day)
    Step 3: Open box
    Step 4: Open Plastic package inside box and remove the voltage booster
    IMG 1 (Voltage booster)
    Step 5: Discard Directions
    Step 6: Open hood
    Step 7: Unplug alternator connection (a small screwdriver may be used)
    IMG 2 (Unplugging the stock wiring)
    Step 8: Plug voltage booster into alternator
    Step 9: Plug stock alternator connection into voltage booster
    IMG 3 (Installed close up)
    Step 10: Close hood. You are done.
    IMG 4 (engine bay post-install)
  2. #2 Re: ZZP Stage 1 Voltage booster install
    Topeka, KS
    Step 11. Drink a Beer.
  3. #3 Re: ZZP Stage 1 Voltage booster install
    SWPA
    Step 12. Take it back off.
  4. #4 Re: ZZP Stage 1 Voltage booster install
    Kemmerer, Wyoming
    on the series 2 cars, or at least mine, it is a pain to do because the connector is on the bottom of the alternator.
  5. #5 Re: ZZP Stage 1 Voltage booster install
    GT Level Member willie14's Avatar
    Jun 2016
    westland mi
    I have installed this. I found one on an alt I found at the yard. Didn't notice difference until I installed an alt rewire I made myself. So now which works the volt booster or alt rewire.......
    98 Grand prix SE to GTP conversion( in works). Full body conversion in works, drilled n slotted rotors, ceramics, all new suspension, custom CAI, NGK wires/Vpower plugs, SD headers, 180 Tstat, AND A WHOLE BUNCH OF PAINT BABY!! Tuned by E&J performance.
  6. #6 Re: ZZP Stage 1 Voltage booster install
    Nov 2011
    NY
    It's garbage... Higher voltage = Less Amperage or less ummmmph! There are no magic pills, the Diaode gimmick may boost voltage on a meter, but it's smoke & mirrors. Only way to get more power is to change alternator. Thanks for listening ; )
  1. ZZP Voltage Booster
    By KoldAsIce in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-09-2013, 10:14 PM
  2. ZZP voltage booster?
    By nos4blood70 in forum General Tech Discussion
    Last Post: 10-15-2012, 11:26 AM
  3. voltage booster
    By bps02gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2011, 08:59 AM
  4. Anyone use The voltage booster/Alt rewire kits?
    By Agentlongwood in forum General Tech Discussion
    Last Post: 11-09-2009, 02:02 PM
  5. Alternator Voltage Booster question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2009, 07:23 AM
