Thread: Aeroforce was working plugged in obd2..now it isnt?
Results 1 to 5 of 5
  1. #1 Aeroforce was working plugged in obd2..now it isnt?
    GTP Level Member
    Nov 2008
    MA
    it worked for months plugged right in the obd2 now it starts up..displays for 2 secs then shuts off blinking red over and over and over..did i blow some sorta fuse? emailed the company but got no response
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  2. #2 Re: Aeroforce was working plugged in obd2..now it isnt?
    You have a seperate power lead for it correct?
  3. #3 Re: Aeroforce was working plugged in obd2..now it isnt?
    GTP Level Member
    Nov 2008
    MA
    yes i do, but question still stands how it just stops working after months of it being in the obd2 port?
    99 GTP - DD
  4. #4 Re: Aeroforce was working plugged in obd2..now it isnt?
    GTX Level Member blackflag's Avatar
    Virginia
    Did you wire it with add a fuse?If so have you checked the fuse you tapped? When I plugged mine up to the port without the power line it did the same as your describing.
  5. #5 Re: Aeroforce was working plugged in obd2..now it isnt?
    Florida
    Check the fuse you should have added. If you didn't, check the power source you did tap it into.
    All else fails, replace the Cig lighter fuse (where most people tap theirs, it goes bad, and people scratch their heads)
  1. Temp Gauge not working...Aeroforce says 180
    By wa04compg in forum General Tech Discussion
    Last Post: 04-02-2012, 06:29 AM
  2. Chatbox isnt working for me...
    By Tengis in forum Forum Bugs/Suggestions
    Last Post: 12-22-2011, 11:42 PM
  3. Aeroforce Interceptor Not Working
    By TheAce144 in forum General Tech Discussion
    Last Post: 08-30-2011, 03:39 PM
  4. Aeroforce gauge not working..
    By GrandPrixGTP1 in forum General Tech Discussion
    Last Post: 02-28-2011, 01:01 PM
  5. aeroforce stopped working now blinks red?
    By AmericanSoldier in forum General Tech Discussion
    Last Post: 12-06-2010, 07:56 PM
