it worked for months plugged right in the obd2 now it starts up..displays for 2 secs then shuts off blinking red over and over and over..did i blow some sorta fuse? emailed the company but got no response
yes i do, but question still stands how it just stops working after months of it being in the obd2 port?
Did you wire it with add a fuse?If so have you checked the fuse you tapped? When I plugged mine up to the port without the power line it did the same as your describing.
Check the fuse you should have added. If you didn't, check the power source you did tap it into.
All else fails, replace the Cig lighter fuse (where most people tap theirs, it goes bad, and people scratch their heads)
